Bolt strength question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 8th, 2007, 08:14 PM   #1
nd4spd71
nd4spd71's Avatar
Default Bolt strength question
I made some shackle mount brackets to go on the rear of my '86 chevy pickup that I am building for a trail rig. They are setup to use the 3 factory mounting holes for the stock rear bumper, (which has been removed) plus one more that I will have to drill. My question is will 4 - 1/2" diameter Grade 8 bolts be strong enough to hold up to the stress of pulling a full size rig out if it is stuck? Thanks in advance for your help.
nd4spd71 is offline   Reply With Quote
Old October 8th, 2007, 08:18 PM   #2
95geo
newbie
95geo's Avatar
yes, just make sure they are torqued properly and the holes arent oversized too much
Old October 8th, 2007, 08:24 PM   #3
IDIeselman
IDIeselman's Avatar
A grade 5 will have a higher shear strength but you will be more than fine with the 8.
Old October 8th, 2007, 08:30 PM   #4
nd4spd71
nd4spd71's Avatar
Where would I find the torque specs for them? If I remember right the holes are .550 so I should be good there.
Old October 8th, 2007, 08:30 PM   #5
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
In this app. they are under tension and not in a shear load. So a 8 is great when in dought over kill.
Old October 8th, 2007, 08:32 PM   #6
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
95 on NC
110 on NF
both 0.50" dia
Old October 8th, 2007, 09:06 PM   #7
nd4spd71
nd4spd71's Avatar
Thanks all
Old October 8th, 2007, 09:07 PM   #8
Also, I Believe that when this has been stated before, the 8's are still stronger in shear, as well.
Old October 8th, 2007, 09:15 PM   #9
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
8's are stronger all around. A grade 5 will bend before it fails, where a grade 8 won't. Still there is almost no application (besides cost) that a 5 is better than an 8.
The one thing 8's have problems with is that a nick or a notch in the bolt really cut down their strength.
JcrOffroad
Zoom Zoom!
Old October 8th, 2007, 09:17 PM   #10
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Also be sure to use a grade 8 lock nut not a 5 nylock like some people do.
Old October 8th, 2007, 09:18 PM   #11
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Yes they are. Shear is figured at 60&#37; of it's tensile strenght.
Old October 9th, 2007, 12:13 AM   #12
BIGBEN
All out Idiot
BIGBEN's Avatar
biggest mistake i see.
always make sure all your hardware matches.
Originally Posted by Stan View Post
My hope is that one day all women will realize just how well they could have it if they just shut their big fucking whining mouths.
BIGBEN is offline   Reply With Quote
Page generated in 0.44385 seconds with 59 queries
