All the parts are in the same zip code now.... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 10th, 2005, 12:29 PM   #1
blizazer
blizazer's Avatar
Send a message via AIM to blizazer
Default All the parts are in the same zip code now....
...now all I have to do is piece them together.
Start with a caddy big block:
Motor 1
Motor 2
Add an s-blazer frame:
Frame 1
Frame 2
Add a D44 front:
Rollin
Add a single cab S10 cab, TH400, np203:
Sorta together
Add a 14 bolt rear and some bigger tires:
Rear shot
Add some steering linkages (still need to clean that up):
Steering
And the whole thing looks a little less horrible in this shot:
Rust, what rust?
Its a cut and paste mutt project from over 10 vehicles now. Ive been having excellent luck with getting cheap or free parts at each step of the way.
The next step is getting that front suspension redone to handle the weight that its seeing now, finishing some brake plumbing, setup the cooling system, and then its ready for the first lawn victory lap.
There's still the winch mounting to handle, some sheet metal on the front end, roll cage / exo, wiring, gas tank, shift linkages, blah blah blah...
It takes time, but I'm having a blast learning. The basic goal of it was have a toy to trailer around, and start learning what I dont know that I dont know about building ground up.
blizazer is offline   Reply With Quote
Old November 10th, 2005, 05:30 PM   #2
GMCsonoma94
1 wheel peel
GMCsonoma94's Avatar
Send a message via AIM to GMCsonoma94
shes comein along nicely, cant wait to bury in the back yard this summer
<-----in that hole
GMCsonoma94 is offline   Reply With Quote
Old November 10th, 2005, 05:35 PM   #3
blizazer
blizazer's Avatar
<-----in that hole
I dont get your facination with that hole Ryan. Theres no path, it doesnt go anywhere... you just drive in it and get stuck!
I'd rather go somewhere that I've got a chance of getting through.
I guess I better think up something for winching backwards if you make me go in there.
Old November 10th, 2005, 06:02 PM   #4
Chop
Mischievous Badger
Chop's Avatar
hey looking good what are you thinking of doing with the exhaust ??
Old November 10th, 2005, 06:20 PM   #5
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Ryan seems to have a thing for holes in the back.....
Old November 10th, 2005, 06:51 PM   #6
Mclovin
"The Situation"
Mclovin's Avatar
HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA HAHAHAHAHA
HA ! Looks like a sweet project man !!!
Old November 10th, 2005, 09:01 PM   #7
GMCsonoma94
1 wheel peel
lol you just gota make a path between thos bushes thats where i was goin
Old November 10th, 2005, 09:23 PM   #8
Pongking23
CHOP'S Idol
Pongking23's Avatar
Send a message via AIM to Pongking23
hahaha, commin along good man
Pongking23 is offline   Reply With Quote
Old November 10th, 2005, 11:01 PM   #9
blizazer
blizazer's Avatar
I saw a maroon 90s chevy at the mud bog last weekend, I think I'm going to rip off his exhaust idea.
He had headers arranged the same way as my manifolds, mufflers directly attached, and chopped holes in the hood.
With the height of the cab over the motor right now, I might be able to clear some short mufflers and only have to hack holes in the hood for exit pipes. Otherwise, muffler sized holes.
Or I could go wtih my texan buddy's idea and bring both pipes straight up, then bend them into longhorns for the front.
Thanks for the comments guys.
Old November 11th, 2005, 10:32 AM   #10
FrischJ
aka MrDrift
FrischJ's Avatar
I still need to drive into that hole and get stuck, it's a 36m tradition now!
FrischJ is offline   Reply With Quote
Old November 13th, 2005, 03:54 PM   #11
KetteringRedneck
KetteringRedneck's Avatar
Send a message via AIM to KetteringRedneck
You had to show my welding skills in the steering pic didn't you. I am not responsible it that sucker breaks and you hit a tree.
KetteringRedneck is offline   Reply With Quote
Page generated in 0.35833 seconds with 56 queries
