amc 20 bearing info needed - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 7th, 2007, 03:54 PM   #1
booblinker
Sore and Tired 24/7
booblinker's Avatar
Default amc 20 bearing info needed
i am trying to do the wheel bearing on my 82 cj7. I pulled the big nut, the 4 bolts on the flang, and unbolted the ring gear, but those shafts still wont come out. Am i forgetting something or are they just seized in?
Old October 8th, 2007, 05:55 AM   #2
PavementPounder
PavementPounder's Avatar
Its a tapered bearing, so they will be in there tight. You'll need a slide hammer or some other method by which to pull on the shaft. In the past I have put the wheel back on and used a big ratchet strap around it attached to something immobile.
And what to you mean you unbolted the ring gear?
Old October 8th, 2007, 09:42 AM   #3
itselliott
itselliott's Avatar
Reversing an OLD brake drum and putting several lug nuts on the studs (leaving a gap) use the drum as a slide hammer...........all 4 bolts need to be out of the retainer plate.
And x2, what DO you mean you unbolted the ring gear?
Pretty much what PP said
Old October 8th, 2007, 11:11 AM   #4
booblinker
Sore and Tired 24/7
booblinker's Avatar
im taking the whole rear end out so i can weld it, i unbolted the whole ring and spider assembly.
Page generated in 0.16057 seconds with 35 queries
