Couple axle questions... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 7th, 2007, 01:10 PM   #1
ttocsnekia
Fawkin' Noobs
ttocsnekia's Avatar
Default Couple axle questions...
Front and rear axels off 85 GM 6.2 L Diesel
I talked to the guy and he said it was a camper special, but was only six lugs. He is older so he might be crazy. What axles is the truck supposed to have? I can't imagine that they would put 1/2 ton axles behind the 6.2
Another one.
1976 GMC 1-Ton 4x4
350 4 speed. 7 Western Plow
Body is Junk.
cab seperated wiring harness.
Plow works great.
Thanks,
Scott
ttocsnekia is offline   Reply With Quote
Old October 7th, 2007, 01:25 PM   #2
kickstand
circling the drain
kickstand's Avatar
the one ton should hav ea 60 up front and a 14 bolt rear.
The camper special is most likley a semi floating 6 lug 14 bolt and a dana 44 or 10 bolt front.
It could also be a 12 bolt rear on the camper special, but I thought those went away in 79-80ish.
Page generated in 0.24740 seconds with 29 queries
