1998 ZJ running problems - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 6th, 2006, 06:36 PM   #1
shawn
Resident HVAC/R Jambi
shawn's Avatar
Unhappy 1998 ZJ running problems
I am at a loss. I can't figure this out. When it is not fully warmed up it runs like crap, idles like crap, and stumbles and sputters when accelarating at a light. If I start it and let it idle in park, while warming up it will start to idle very ruff, and the rpms will slowly drop. So yesterday, I let it warm up, I took off hte air horn, and watched what the IAC was doing, it would gradually open, and keep opening wich would make the motor run very lean and it would almost want to stall. So I stuck my finger in the IAC hole to plug it some, and it helped lots. Or if I 'jook' the gas then it will idle for a little bit then start stumbling again. When this thing is warmed up it seems to be much better.
What is telling the IAC what to do (besides the computer), what sensors effect the actions of the IAC? MAP, IAT? TPS?
I still need to check my belly pan gasket on the intake, that mat be a problem but it can't be all the problem.
Old March 10th, 2006, 06:38 PM   #2
Andre1
If you plug the IAC off and it runs better then you need to look for a vacuum leak. The engine should stall with the IAC pluged off. My brothers had a vacuum hose off at the vacuum acumulator (big plastic ball) that controls the heater controls. Good luck.
Andre1 is offline   Reply With Quote
Old March 10th, 2006, 08:59 PM   #3
shawn
shawn's Avatar
Yeah, I tried that, I plugged it with my finger and it stalled. The problem is, until the motor is fully warmed up, something is telling the aic to open, it slowly opens until I have about 100 rpms. And then when you take off it won't close (I think).
Page generated in 0.15774 seconds with 32 queries
