Early Bronco D44 Specs? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 4th, 2007, 09:29 PM   #1
bitchofanxj
Are you cooool maaaann?
bitchofanxj's Avatar
Thumbs up Early Bronco D44 Specs?
Interested in purchasing with the radius arm style suspension, just wondering what the wheelbase would be comparable to. HP or LP? Lug pattern? I've been told specs before but just wondering what is accurate. Any info that anyone has would be great, or if someone could direct me to the information. Thanks.
bitchofanxj is offline   Reply With Quote
Old October 5th, 2007, 12:15 AM   #2
jeeptjpaul
jeeptjpaul's Avatar
The width should be around 58-60", not sure exactly. 5x5.5 bolt pattern, low pinion.
jeeptjpaul is offline   Reply With Quote
Old October 5th, 2007, 06:42 PM   #3
bitchofanxj
Did any of them come in HP?
Old October 5th, 2007, 06:44 PM   #4
FlamesFearMe
Custom User Title
FlamesFearMe's Avatar
I beleive that you can get a HP44 from an F250, but don't think that the bolt pattern would be the same as the rear 8.8.
FlamesFearMe is offline   Reply With Quote
Old October 5th, 2007, 07:07 PM   #5
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Nope, you can narrow a F-150 on the long side to the same width. Another down fall is that they are all the small 260 ujoint.
early 70's to 77 f-150 or a 77.5 to 79 f-250 are the good hp housings.
Page generated in 0.34613 seconds with 38 queries
