90 ram card 318 help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 4th, 2007, 12:47 PM   #1
farm_boy
hicktown
farm_boy's Avatar
Default 90 ram card 318 help
so i have no gas going to the carb its a in the tank pump is there a relay for the pump or is my gas line pluged up
farm_boy is offline   Reply With Quote
Old October 4th, 2007, 02:55 PM   #2
farm_boy
hicktown
farm_boy's Avatar
someone has to kwone something about this truck where is the fuel fitter
Old October 4th, 2007, 05:42 PM   #3
dodgeboy
redneck truck club
dodgeboy's Avatar
if its a electric pump in the trank theres a relay but on the other hand my 84 ramcharger had a pump on the frame and on the block its carbed dont know what you mean by "card" but are you sure its not throttle body???
dodgeboy is offline   Reply With Quote
Old October 4th, 2007, 05:46 PM   #4
xjmichigan
xjmichigan's Avatar
no one fukc his questions till he learns to sPeLl
Old October 4th, 2007, 06:10 PM   #5
user name
keep your stick onthe ice
user name's Avatar
I think he needs to slow down the typing. That or type into a word processor then copy and paste here.
on a side note the fuel filter is on the driver side frame rail or a crossmember next to the gas tank. a 90 would be fuel injected unless it's been fucked with. The pump should be in the tank. With a relay somewhere and also a fuse I would bet it will end up the pump thats the same age mine was when it went out. You can get the plugin off the tank without dropping it or lifting the bed to check for voltage and ground back there.
Old October 4th, 2007, 06:16 PM   #6
farm_boy
hicktown
farm_boy's Avatar
didnt check well do and thanks for the help its a tbi
Page generated in 0.20598 seconds with 41 queries
