Is this a D60? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 2nd, 2007, 10:39 AM   #1
thrill20
thrill20's Avatar
Default Is this a D60?
This is the front axle from a "70's" ford. My 3/4 ton d44 does not have knuckles like that. Is it a 60? I don't know front axles that well. I can get the whole frame/drive train pretty cheap. It has eight bolt rear as well. I'm assuming the rear is a 60. Any help or opinions are appreciated.
Thanks, Will
thrill20 is offline   Reply With Quote
Old October 2nd, 2007, 10:40 AM   #2
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
I'd run away. I don't like the closed knuckle axles.
Old October 2nd, 2007, 10:48 AM   #3
thrill20
thrill20's Avatar
for maintenance? strength? I haven't done much axle work yet, so enlighten me....
Thanks.
Old October 2nd, 2007, 10:52 AM   #4
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Parts availability would be my #1 reason, and for me it is a show stopper.
I have read internet lore that they are weaker, but I have no proof of it. Since I can't get past reason #1, I haven't put any real effort into researching if they are weaker.
Old October 2nd, 2007, 10:54 AM   #5
There's nothing wrong, per se, with closed knuckle, but that axle is just outdated. You don' thave the same shafts/joints, so finding aftermarket stuff isn't going to happen.
The only two downsides I see to closed knuckle is the reduced turning radius compared to most open knuckles, and they are messy to service.
Othre than that, I'm rather partial to my closed knuckle front...
Old October 2nd, 2007, 10:54 AM   #6
btw, that could be either a dana 44 or a dana 60....
Old October 2nd, 2007, 10:55 AM   #7
95geo
newbie
95geo's Avatar
if you want to put a lot of money into it then stay away, if you want the center section then grab it.
to the average guy it probably isnt worth more that $200... I personally would walk away like johnnyj said.
Old October 2nd, 2007, 10:57 AM   #8
Renegade II
Coil springs are for pens
Renegade II's Avatar
I've had two vehicles with early style closed knuckle axles. Both failed under moderate (at worst) wheeling and had to be replaced. Also, front drum brakes suck bad.
Old October 2nd, 2007, 11:16 AM   #9
thrill20
thrill20's Avatar
Well, I can get the complete frame with engine/trans/t.c. and axles for $300. I don't really need the rest, but was hoping the front axle would work out. I don't know the exact year, but it is supposed to have a 360. So I'm guessing early 70's. I may still take a look at it and see if the rest of the parts are in ok shape. Never hurts to have spares.
Thanks for the input.
Old October 2nd, 2007, 11:26 AM   #10
hawkscj5
Skinny Pedal Crawler
hawkscj5's Avatar
look on the side of the block it will say what c.i. it is
hawkscj5 is offline   Reply With Quote
Old October 2nd, 2007, 12:02 PM   #11
PavementPounder
PavementPounder's Avatar
If its a D60, it should be LP. I would walk also. Too much effort for little return.
Page generated in 0.28411 seconds with 56 queries
