lower control mount - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 5th, 2006, 08:56 PM   #1
kevp77
I break it!
kevp77's Avatar
Send a message via Yahoo to kevp77
Unhappy lower control mount
Suggestions??? Just try to bend them back and get a new bushing. Severity?
kevp77 is offline   Reply With Quote
Old March 5th, 2006, 09:13 PM   #2
Blackjackbender
get a new one welded on, aftermarket ones at 50 bucks or so and are 3/16".
i may have an extra one in my garage i would sell you and could probably weld it on for you if needed. ill check to see if its drive side or passenger.
pretty sure its passenger though.
Ty
Old March 6th, 2006, 08:01 AM   #3
shawn
Resident HVAC/R Jambi
shawn's Avatar
I've helped a coule of people with thiers. They ordered the RE ones, but they arlready had adjustable lower arms, so they could still adjust thier caster. The new HD ones will not have the cam adjustemnt in them. So just get some good ones and weld them on.
Old March 6th, 2006, 11:15 AM   #4
Blackjackbender
im pretty sure it is for the passenger side. i will double check. its a rubicon express mount. Ill sell you it for 40 dollars if you are intrested.
take it easy,
Ty
Old March 6th, 2006, 04:52 PM   #5
Jeeptj1999
Jeeptj1999's Avatar
Jeeperz Creeperz has em in stock and can do the welding if your interested.
Jeeptj1999 is offline   Reply With Quote
Old March 9th, 2006, 11:43 AM   #6
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
There's probably nothing wrong with the bushings. Just install these:
They're even slotted for the cam bolts to work. $47.99/pair
Jeeperz Creeperz, Inc.
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
www.jeeperz-creeperz.com
Old March 9th, 2006, 01:20 PM   #7
Immortal
NO RELIGION WAT!
Immortal's Avatar
Been there, fixed that $35 a pair and 6.35mm thick
Old March 9th, 2006, 06:16 PM   #8
Jeeperz Creeperz
GL 4x4 Vendors
Damn metric system! Why can't you just say 1/4"?:miff:
Well, I can't beat that.... where can he pick some up?
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
Old March 10th, 2006, 08:39 AM   #9
Immortal
NO RELIGION WAT!
Immortal's Avatar
my garage.....I have only one set left for a 2.5 axle tube. I also have sets for 3 and 3 1/4" axle tubes. At a previous shop I worked at I made a mess of these, and thought they would sell like hotcakes Oh well :)
Old March 10th, 2006, 05:07 PM   #10
kevp77
I break it!
kevp77's Avatar
To Start
After
Step 1
Step 2
The Problem now
AFTER 5000 MILES
The Fix
http://www.quadratec.com/cgi-bin/sgi...M=00&checked=Y
going with new mounts when i put the new lift on ...
Before
After
Old March 10th, 2006, 06:38 PM   #11
Jeeperz Creeperz
GL 4x4 Vendors
That is not an actual seal. It's supposed to keep debris out of the axle tubes. If you've got water in your diff then either the inner axle tube seals are leaking, the pinion seal is leaking, or it's getting in through the vent tube.
The Problem now
AFTER 5000 MILES
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
Old March 10th, 2006, 06:47 PM   #12
junk90xj
ALLPRO AUTO
junk90xj's Avatar
x2
http://www.apalansing.com/
Old March 10th, 2006, 07:06 PM   #13
Immortal
NO RELIGION WAT!
Immortal's Avatar
You do realize that bending that lca mount back is only a temporary fix. The metal is now fatigued. It will eventually bend again or worse rip. Even more so if you wheel it. As far as the water going into the tube ends make sure you also check the vent line did not fall off the back of the diff.
Old March 10th, 2006, 08:05 PM   #14
kevp77
I break it!
kevp77's Avatar
putting on new mounts when I put the re 4.5 on in a couple weeks
Page generated in 0.46507 seconds with 65 queries
