Comcast cable? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 5th, 2006, 08:44 PM   #1
Ice Princess
I'm just here
Ice Princess's Avatar
Send a message via AIM to Ice Princess Send a message via MSN to Ice Princess
Default Comcast cable?
I have one cable out-let. From that I have a 3 way splitter. One for the living room (which works fine, gets all the channels), one for the computer (also works fine), and the 3rd for the TV's in the bedrooms.... those has issues. For what ever reason the bedrooms don't get channel 2, 4, sometimes 7??
I don't get it, why do the other channels come in fine and those don't?
And ideas? Or should I call Comcast?
Ice Princess is offline   Reply With Quote
Old March 5th, 2006, 08:48 PM   #2
PavementPounder
PavementPounder's Avatar
Buy a booster.
Actually, I have a couple extras.
Old March 5th, 2006, 08:49 PM   #3
Cube
Captain of my pants
Cube's Avatar
does the splitter look cheap, how do the cable ends look? compression or crimp on?
Cube is offline   Reply With Quote
Old March 5th, 2006, 08:50 PM   #4
Ice Princess
I'm just here
Cable and splitters are good.
Old March 5th, 2006, 08:53 PM   #5
rallyemore
Snowman
rallyemore's Avatar
Send a message via AIM to rallyemore
Is that the longest wire? it could be that it's loosing strength the longer it gets.
rallyemore is offline   Reply With Quote
Old March 5th, 2006, 08:54 PM   #6
Its most likely the cables. We have had similar issues with the low numbers, especially 4, at the end of a long run of cheap cable.
Old March 5th, 2006, 08:54 PM   #7
Cube
Captain of my pants
Cube's Avatar
the lower channels like 2 come in a lower freq. so that is why some lower channels might work and your higher will work, usally its the other way around tho, the higher channels aka freq has greater lose and you lose chanels there, sounds like your drop might have water in it if everything else is fine
Old March 5th, 2006, 08:59 PM   #8
Ice Princess
I'm just here
Cool... yeah the cable probably should be thicker.
Old March 5th, 2006, 09:05 PM   #9
Cube
Captain of my pants
Cube's Avatar
hehe ok more question you said bedrooms and tvs so there has to be another splitter, what kind of splitter are those off of, if you have a normal three way right off the bad your lost should be 5.5 dbmv off each leg and if you have another 2 way for maybe two bedrooms you will be loosing a another 3.5 dbmv off each leg and sounds like you have old RG59 running in your apartment so even 100 ft of that you could be loosing 10dbmv, but like I said you should be loosing your higher channels before your lower ones unless you have a drop problem
Old March 5th, 2006, 09:19 PM   #10
Sandals
Fucking Zen as Shit
Sandals's Avatar
Originally Posted by Cube
three way
sorry lost me there
Sandals is online now   Reply With Quote
Old March 5th, 2006, 09:22 PM   #11
BigBlkYJ 355
U-Joints Fear Me
BigBlkYJ 355's Avatar
if its not already, use RG-6 cable. we had the same problem with the local channels in our house, upgraded to bigger cable (RG-6) and bought a small booster and it was fine.
Old March 5th, 2006, 09:26 PM   #12
PavementPounder
That's why she needs one of these 12 or 15db boosters I have here!
Page generated in 0.29036 seconds with 58 queries
