The tube that the front body mount is attached to - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 5th, 2006, 09:23 PM   #1
Tie Dyed
O.G.
Tie Dyed's Avatar
Send a message via AIM to Tie Dyed
Default The tube that the front body mount is attached to
If I cut that out, and then put some 1/4 inch flate plate in there, do you think it will do the same thing? I am looking to mount my winch there. I am getting the tube ready to bend for my new grill gaurd and fenders, and a little other stuff, and that tube is pissing me off.
So what are your thoughts about it?
2000 XJ with a 3 inch body lift
Tie Dyed is offline   Reply With Quote
Old March 5th, 2006, 11:06 PM   #2
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Why would you need to cut it out? There are holes on the top of the frame to bolt a 1/4 inch winch plate to. Mine is 3/8's angle.
Old March 6th, 2006, 05:09 PM   #3
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
You don't know Tie then do you?
Old March 6th, 2006, 05:27 PM   #4
nixxerRsixxer
Homewrecker
nixxerRsixxer's Avatar
my guess is maybe he wants to move it 4" lower...
yes you can cut out the front crossmember.. mines gone..
but i also have a new 3/16 2x4 bumper welded to the front..
nixxerRsixxer is offline   Reply With Quote
Old March 6th, 2006, 09:05 PM   #5
Tie Dyed
O.G.
Tie Dyed's Avatar
yes, I want to move the winch lower, and don't want to run a winch bumper or anything like that. Also don't want to weld the bumper in there. I was thinking I would weld it just above the steering pump, on extend the frame about 4 inches or so, and weld it at the bottom of the frame, and then mount my winch to it. Still figuring out what I ant to do for the bumper, something low profile. I don't plan on running a stinger, but will have the rad. mounted to the hoop that I am going to build over it, and tie the tube fenders into that, and then the frame.
If you ever have seen hosejocky's cj-7, something like that, just modified a little for what I want.
Old April 10th, 2006, 05:29 PM   #6
Tonka
Tonka's Avatar
http://www.tommyjeep.com/projects/20...work/index.asp
Page generated in 0.21993 seconds with 41 queries
