'76 K-5 Coilover front end, cage, 468 BBC - Page 9 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 27th, 2008, 08:04 PM   #161
DUNE JUMP
DUNE JUMP's Avatar
Originally Posted by Searchin4acj View Post
looks good man what do you plan on doing to the engine?
Engine plans:
.020 over 350 4-bolt block, still needs to be honed
TRW hypereutectic alum pistons
crane cam
MSD distributor
Cloyes timing set
2.02 heads, ported and polished
air-gap manifold
holley 600
need a deal on some machine work if anyone knows anyone
Old October 28th, 2008, 09:34 PM   #162
jcp962002
jcp962002's Avatar
www.dsengine.com is the machine shop at the end of elmwood at Rochester; I don't think they will give you much of a deal but there close; they also do radiator's
jcp962002 is offline   Reply With Quote
Old November 4th, 2008, 10:06 PM   #163
DUNE JUMP
DUNE JUMP's Avatar
Two close-out panels added tonight--
Just heard the news - OBummer '08
[New] powerplant getting torn down and prepped for installation
350, forged flat top pistons, 1.94 valve heads, going to be adding an air-gap intake, either pocket porting the heads, or adding my set of 2.02 heads after porting, adding comp cam & lifters, cloyes timing set, MSD distributor, 750 double pumper, and old set of headers. Should be ~325-350hp
Old January 5th, 2009, 10:21 PM   #164
DUNE JUMP
DUNE JUMP's Avatar
Default Update 1/5/09, plus year in review
I know I should be working on swapping axles in the diesel tow rig I picked up, but I really wanted to get my hood mounted on the K5.
Also started porting my set of 2.02 heads, I decided that I'd be porting a set of heads anyway, might as well go with the bigger set.
Year in review:
  • 10 point cage built
  • top chopped
  • front links built
  • steering built
  • coilovers mounted
  • dash built
  • console added
  • Audi S4 seats installed
  • 12 gallon fuel cell replaced stock 31 gallon tank, plumbed with stainless flex line
  • original 350 pulled, started buildup of new 350
Oh, and we had triplets...
Old January 6th, 2009, 02:55 AM   #165
VonDirt
VonDirt's Avatar
nice work, its looking good - i like the year in review. but in light of this . . . .
its amazing !!
(weve got three as well) - but not all at once
hang in there
VonDirt is offline   Reply With Quote
Old January 6th, 2009, 06:49 AM   #166
DUNE JUMP
DUNE JUMP's Avatar
Thanks for the compliments :) It's been a crazy year, sometimes the garage is the only way to keep my sanity. I think that's what they're for though...
Next up is mounting the fenders- I pushed the hood back into the cowl area where the original close out panel would be, so the fenders will be moving back as well. I'll be getting creative with the wheel openings and trimming at the door edge... Thanks to Nick (searching4aCJ) I got my doors back and I am planning to skin them and mount similar to the way I'm doing the fenders-- 1/4-20 countersunk cap screws and cone washers to light tabs and tubework, so I have the option of running "doors" if I want. Probably will have to add a tube at the bottom of the window opening to give something to sit on when getting in with the doors on.
Once all this little BS stuff gets knocked out I'll get more focused on the engine. I really need this thing done for Silver Lake this year. I can't wait!!
Old January 6th, 2009, 10:44 AM   #167
SFA BlaZeR2
Who needs MPG?
I would love to give you a hand some day. I would be up for another blazer day. We need to get yours running again, and then I need to revive mine this spring. I do plan on taking it out a few times next year. I am saving up some money so that I can get 4x4 going.
SFA BlaZeR2 is offline   Reply With Quote
Old January 6th, 2009, 12:52 PM   #168
mtxbigtruckin
Wheelin' Since Birth
mtxbigtruckin's Avatar
Sweet work man, again let me know if you ever need help, I'm in the area!
mtxbigtruckin is offline   Reply With Quote
Old January 7th, 2009, 09:01 AM   #169
DUNE JUMP
DUNE JUMP's Avatar
Thanks guys, I'd like to have another Blazer day, got a ton done last time... just have to figure out when it will work. I'll keep you guys posted-- just hate to bug you to help for an hours worth of time...
Old January 7th, 2009, 10:10 AM   #170
mtxbigtruckin
Really, if I'm home bored, an hour is cool with me, just give me a shout.
Old January 7th, 2009, 10:37 AM   #171
two_much_talk
sit down shut up and ...
two_much_talk's Avatar
when do you expect to get this thing runnin ?
Old January 7th, 2009, 10:42 AM   #172
DUNE JUMP
DUNE JUMP's Avatar
I'm setting my goal on opening day of Silver Lake... that gives me ~3 months. I think I can, I think I can...
Old January 7th, 2009, 10:43 AM   #173
DUNE JUMP
DUNE JUMP's Avatar
Alright sweet, thanks!
Old January 9th, 2009, 08:47 AM   #174
Danza
Silver_Rubicon
Danza's Avatar
Keep up the good work, it's getting closer!
I’m sure you racked-up enough brownie points with the wife to have a blazer weekend by now… let me know when you want some help!
Did you install those gears yet? is that still even on the to-do-list?
Danza is offline   Reply With Quote
Old January 9th, 2009, 09:45 AM   #175
DUNE JUMP
DUNE JUMP's Avatar
Thanks, the gear install is still on the to-do list, but that list keeps getting longer! I got one fender mounted last night, took about an hour and a half, but I made enough brackets and supports for the RH side so it should go faster. I originally was going to use DZUS fasteners, but at ~$4 per assembly, I opted for 1/4-20 countersunk bolts and tapered washers. I think it's turning out pretty well though. I'll post pics once I get the other fender mounted.
Old January 9th, 2009, 10:16 AM   #176
Bronco Ollie
Captain Jack Sparrow
Bronco Ollie's Avatar
sweet looking k5
Bronco Ollie is offline   Reply With Quote
Old January 20th, 2009, 04:10 PM   #177
Danza
Silver_Rubicon
Danza's Avatar
Default Tranny x-member?
I was reading back thru your build... man has this thing come along way! But I couldn’t remember if you ever went back and gusseted this “Flap” of steel with a tub welded to it that you’re calling a transmission cross-member? Looks a little shady, not that I haven’t done worse, but this isn’t about me…
if I remember right I think you did something different with it??
Old January 20th, 2009, 04:58 PM   #178
Bones
Bones's Avatar
Is that what you dragged to work today?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old January 20th, 2009, 05:47 PM   #179
four_by_ken
Need a strap?
four_by_ken's Avatar
Did you ever finish up the front suspension? I looked back at the pictures and I dont see the final setup. Did I miss it?
four_by_ken is offline   Reply With Quote
Old January 21st, 2009, 07:48 AM   #180
DUNE JUMP
DUNE JUMP's Avatar
Originally Posted by Bronco Ollie View Post
sweet looking k5
thanks man
haha yeah, old D70 with tall gears, had to drop it off in Ypsilanti to ship. Some lucky guy in Texas is getting a 520 lb present.
Page generated in 0.73589 seconds with 84 queries
