'76 K-5 Coilover front end, cage, 468 BBC - Page 8 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 24th, 2008, 06:29 PM   #141
mtxbigtruckin
Wheelin' Since Birth
mtxbigtruckin's Avatar
I gotta get over there to see that thing sometime. Let me know when you're working on it again.
mtxbigtruckin is offline   Reply With Quote
Old August 24th, 2008, 08:44 PM   #142
muddin_wolverine
muddin_wolverine's Avatar
Originally Posted by DUNE JUMP View Post
The body stayed at the same height to the frame, but I ditched the rubber mounts and moved the frame mounts up ~2 inches so I could bolt straight to the body. They are kinda of overkill since the body/cage is tied to the frame in 10 places.
im thinking about doing the same when i get rid of my body lift cause i want to run the cage through the cab into the bed, would it be possible to just use a piece of steel the thickness of the rubber instead of lifting the frame mounts? it will be much easier for me, since its a part time dd, but i still want it to be solid
muddin_wolverine is offline   Reply With Quote
Old August 25th, 2008, 06:12 AM   #143
DUNE JUMP
DUNE JUMP's Avatar
Yeah, I priced it from metal express or whatever that place is called that will cut and ship to you- www.metalexpress.net in 6061 aluminum and it was like 60-80 bucks to have aluminum pucks made for all the mounts. I was just going to drill the centers and run the original bolts through them. Then I got my plasma cutter and realized how easy it was to just blast the rivets off and move those puppies up. I looked for a while for a cheaper set of spacers, since that is easier. Try looking on pirate for a used 1" body lift for a K5 or Jeep and use those pucks.
When you do your cage are you going to cut the roof off to weld 360 degrees on all the upper joints or design the cage to drop through the floor once it's tacked to weld the top? Something to think about before you start designing. Sounds like a good project though, keep me posted-
Old August 25th, 2008, 06:18 AM   #144
DUNE JUMP
DUNE JUMP's Avatar
This is my plan to close out the center console area. I'm thinking a little tube enclosure for the battery with a hinge and a latch would be good also.
Old August 25th, 2008, 06:58 AM   #145
DUNE JUMP
DUNE JUMP's Avatar
I'm supposed to get a day in the garage one of these weekends, but it's tough to plan it. I tend to get 15 minutes here and there, and not too much more. We are going to the dunes this weekend though!
Interested?
Old August 25th, 2008, 07:49 AM   #146
mtxbigtruckin
already planning on it, staying at Silver Hills. What will you be driving?
Old August 25th, 2008, 07:52 AM   #147
DUNE JUMP
DUNE JUMP's Avatar
You're welcome to stay at my folk's place there if you want to save some $. Let me know-- I'll be driving the silver XJ with triplet sticker on the back and the saggy springs missing two LH flares with the front end falling off.
Old August 25th, 2008, 03:21 PM   #148
Danza
Silver_Rubicon
Danza's Avatar
I see your MS Paint skills are improving, Iím glad those lessons paid off.
.... I'll be driving the silver XJ with triplet sticker on the back and the saggy springs missing two LH flares with the front end falling off.
what the hell did you do to that nice little silver jeep?
Danza is offline   Reply With Quote
Old September 25th, 2008, 08:59 AM   #149
DUNE JUMP
DUNE JUMP's Avatar
The nice little silver Jeep is doing well. She gets me to work and back every day, so I can't complain.
I need to get some new K5 pics up though...
Old September 25th, 2008, 09:45 AM   #150
mtxbigtruckin
Probably in better shape than mine. Mine's missing shocks, a radiator and still has trees in the rims again for the 3rd time! Going back to the dunes October 24-26th, should have about 15+ trucks up there.
Old October 22nd, 2008, 11:54 AM   #151
DUNE JUMP
DUNE JUMP's Avatar
Saturday is going to be a thrash fest to get as much done as possible. Pics to follow :)
Old October 22nd, 2008, 12:10 PM   #152
Danza
Silver_Rubicon
Danza's Avatar
Default thrash fest?
i'll bring my axe!
Old October 22nd, 2008, 12:20 PM   #153
mtxbigtruckin
Dune bound this weekend, 50 people, 20+ trucks and Jeeps.....
Old October 22nd, 2008, 01:14 PM   #154
DUNE JUMP
DUNE JUMP's Avatar
i'll bring my axe!
sweet, I'm not sure what you're going to use it on... maybe substitute the sawzall for the axe?
Old October 22nd, 2008, 01:15 PM   #155
DUNE JUMP
DUNE JUMP's Avatar
Sounds like a good time, one last trip before it's closed for the snowy season
Old October 22nd, 2008, 01:35 PM   #156
mtxbigtruckin
Every October we go, been like 20+ years.
Old October 25th, 2008, 09:39 PM   #157
DUNE JUMP
DUNE JUMP's Avatar
Default Blazer day 2008
Today was a big sucess, thanks to my buds that came out to help jump start this project- Brott, John, Chad, and Harris, you guys rock
We got a ton done, here's the list:
Remove stock tank, lines, and plumb fuel cell
tranny cooler lines
Water pump pulley installed
coolant overflow installed
exhaust hangers and collector gaskets
FIRE UP ENGINE, (carb needs a rebuild, rad leaks, but it sounded good)
rear brake prop valve mounted outside the frame rail for quick adjustments
Pull engine, need some long bolts to get it on the stand, then the teardown will begin
Pics!
Thanks DANZA!
Old October 27th, 2008, 07:50 AM   #158
ChevyZ71BP
Default Welcome!
The floor looks alot cleaner too!
ChevyZ71BP is offline   Reply With Quote
Old October 27th, 2008, 07:54 AM   #159
DUNE JUMP
DUNE JUMP's Avatar
Yeah... those 3 qts of tranny fluid really cleaned the floor up nicely
Old October 27th, 2008, 04:42 PM   #160
Searchin4acj
Got Sand???
Searchin4acj's Avatar
Send a message via AIM to Searchin4acj
looks good man what do you plan on doing to the engine?
Searchin4acj is offline   Reply With Quote
Page generated in 0.40518 seconds with 84 queries
