'76 K-5 Coilover front end, cage, 468 BBC - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 25th, 2008, 02:47 PM   #61
DUNE JUMP
DUNE JUMP's Avatar
Originally Posted by bigblazer View Post
Looks good!
Assuming you name is true (dune jump), while your working on things check your passanger side rear shock mount. All 6 of our suburbans at work have broke the frame in half there. And my blazer is starting to crack. All the bottoming out on the dunes seems to really stress the mount and frame right there. Id really suck to jump it and have the frame break. I've been thinking about inbording my shocks to solve the problem (in a / \ way) when I buy new shocks but thats as far as I've got.
My original shock studs in the back cracked the frame a while ago, now I have a little hoop and am running 14" Bilsteins back there thru the bed. Much better setup, but yes inboardinig the shocks is the next best bet. A little hoop from inside of frame rail to inside of frame rail gives you plenty of shock mounting options. Watch out for the motion ratios of the shocks when you get too much angle on them. They start to lose effectiveness.
Not mine obviously, but this is one of the cleanest rear shock mounting setups I've seen on these, actually it might be a Bronco. It's been a while since mine had carpet back there
Old January 25th, 2008, 02:49 PM   #62
DUNE JUMP
DUNE JUMP's Avatar
Originally Posted by Strangler View Post
Why is your trackbar bent? Could you not have moved the frame mount forward so the bar would be just in front of the diff cover?
I'm planning to run the 2wd steering gear up there, so the pitman arm will run towards the rear and take up some frame real estate. The way it is now, I have room under the shallow part of the oil pan, and fit between the pan and the OE engine crossmember. It's tight under there, but it all fits.
Old January 25th, 2008, 02:53 PM   #63
DUNE JUMP
DUNE JUMP's Avatar
Originally Posted by Searchin4acj View Post
hey i like those tires, that thing looks bad ass
I like em too! Thanks for those guys
Coming along....
Old January 28th, 2008, 10:55 PM   #64
DUNE JUMP
DUNE JUMP's Avatar
Default Update 1/28/08
Got a bunch of odds and ends sorted out this weekend and today.
-Steering shaft is done
-Bump stops are in
-Front cab floor tubes are done
-Drag link is done, 14" vertical travel and zero bind, priceless
NEXT UP:
-Coilover mount tubes to frame
-Finish cage work inside
-Mount seats
-Fab dash and maybe a console
-Spare tire mount
-Tube work for front sheetmetal
-Radiator mounting and fan
-Bare bones wiring
-Fire up and systems check
-Replace distributor, cam, heads, timing set, seals
So much to do!! No time to sleep
LOTS OF PICS
Old January 29th, 2008, 07:38 AM   #65
Danza
Silver_Rubicon
Danza's Avatar
Looks awesome and fits like a glove! Keep up the Good Work!!
Danza is offline   Reply With Quote
Old January 29th, 2008, 10:50 AM   #66
Searchin4acj
Got Sand???
Searchin4acj's Avatar
Send a message via AIM to Searchin4acj
cant wait to go wheeling with you, this thing is going to be awesome in action
Searchin4acj is offline   Reply With Quote
Old January 29th, 2008, 12:05 PM   #67
Strangler
Strangler's Avatar
How much room is there going to be between the drivers front tire and the steering box?
Old January 29th, 2008, 12:21 PM   #68
DUNE JUMP
DUNE JUMP's Avatar
Should be plenty, it'll never touch the pitman arm since it swings the same as the tires. The tire never got close to the box before, why, does it look really close?
Old January 29th, 2008, 01:39 PM   #69
Strangler
Strangler's Avatar
It does to me, but I'm used to seeing the box on the inside of the frame. Just stood out to me. Otherwise, Done yet?
Old January 29th, 2008, 02:21 PM   #70
DUNE JUMP
DUNE JUMP's Avatar
Yeah, they tried to give me an inside the frame 2wd box at the junkyard, I had to have them swap it for the 4-bolt outside frame mount box.
I got one of two dash cross bars done this morning, might be on hold for a bit though, my wife got transfered to labor and delivery at the hospital for contractions... hmmm...
"Triplets, stay in there!"
Old January 29th, 2008, 02:57 PM   #71
Strangler
Strangler's Avatar
Congrats!
Old January 29th, 2008, 03:32 PM   #72
DUNE JUMP
DUNE JUMP's Avatar
Thanks bud
Old January 29th, 2008, 03:34 PM   #73
DUNE JUMP
DUNE JUMP's Avatar
Same here, it'll be fun to finally get out with it again, and will be sweet to wheel with you in your K5
Old January 29th, 2008, 03:56 PM   #74
DUNE JUMP
DUNE JUMP's Avatar
Congrats!
Thanks, we're excited and scared at the same time :)
Old January 29th, 2008, 04:20 PM   #75
Searchin4acj
Got Sand???
ya, congrats man
Old January 29th, 2008, 08:42 PM   #76
BIGBADJMY
BIGBADJMY's Avatar
should be the same as the 4x4 box. come on get in the game!
BIGBADJMY is offline   Reply With Quote
Old January 29th, 2008, 08:42 PM   #77
BIGBADJMY
BIGBADJMY's Avatar
nice job! by the way
Old January 29th, 2008, 11:44 PM   #78
DUNE JUMP
DUNE JUMP's Avatar
thanks! I'm more than happy with it so far, now I just have to finish it...
Old February 2nd, 2008, 10:43 PM   #79
DUNE JUMP
DUNE JUMP's Avatar
What do you guys think I should do for door bars on my K5? I don't have any good side views of mine, so I grabbed this pic. I'm trying to tie my front shock tube nodes to the back, add another point to my harness bar behind the seats, and maybe add another point to the top of the a-pillar halo.
Option 1 - normal door x from my front
Option 2 - door x plus a-pillar support (might get too annoying getting in and out
Option 3 - kick a-pillar support tube forward for more room getting in and out
Option 4 - I like
Any other ideas? Is the a-pillar support overkill?
Old February 3rd, 2008, 11:03 PM   #80
Brods
Consider that any bar you put in the "window" area will likely block your visibility somewhat, even more so if you pad it to prevent smacking your face on it.
How were the bars run on the orange truck before you whited them out?
Page generated in 0.45711 seconds with 84 queries
