'76 K-5 Coilover front end, cage, 468 BBC - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 13th, 2008, 01:07 PM   #41
DUNE JUMP
DUNE JUMP's Avatar
Originally Posted by Brods View Post
Are you going to put the roof back on or run without it?
Do you plan an axle upgrade in the future? 10 bolts are weak, especially if you’re planning on jumping the truck.
Are you over on CK5?
Nice looking work, keep the picts coming!
I don't think I will be putting the top back on, but I'm going to save it just in case. I have a 14 bolt in the back, and a dana 44 up front, ideally I would like to swap in a D60, but it's not going to happen very soon. Hopefully the D44 will hold up for a while. I blew out the oiginal 12 bolt rear years ago, so that weak link is gone.
I am on CK5, just don't post much there. Pirate too, but same story.
A few more pictures -
Old January 13th, 2008, 02:48 PM   #42
Searchin4acj
Got Sand???
Searchin4acj's Avatar
Send a message via AIM to Searchin4acj
Looks good man
Searchin4acj is offline   Reply With Quote
Old January 13th, 2008, 04:04 PM   #43
yozsi
Originally Posted by DUNE JUMP View Post
lovin' the california lottery sign.
yozsi is offline   Reply With Quote
Old January 14th, 2008, 08:47 AM   #44
DUNE JUMP
DUNE JUMP's Avatar
Worked some more last night, this has to be some sort of record for me. :chiefwoohaw:
Old January 14th, 2008, 10:05 AM   #45
chevotass
chevotass's Avatar
are you going to bring one more tube down to the frame around where the coilover will mount?
Old January 14th, 2008, 11:36 AM   #46
DUNE JUMP
DUNE JUMP's Avatar
Yep, that's what I'm planning. I think it would be strong enough without it, but it won't hurt to build it to take a relentless beating.
Something like this-
Old January 14th, 2008, 03:16 PM   #47
chevotass
chevotass's Avatar
yep. looks good. better safe then sorry. then you have another option to mount your remote resevoir to also.
Old January 14th, 2008, 03:32 PM   #48
DUNE JUMP
DUNE JUMP's Avatar
You make an excellent point. Plus, the more places I tie into the wet noodle of a frame this thing has, the better.
Old January 14th, 2008, 08:28 PM   #49
jcp962002
jcp962002's Avatar
Any plans to do anything to the engine? just wanted to pipe in since I finally got back on line.
jcp962002 is offline   Reply With Quote
Old January 14th, 2008, 10:19 PM   #50
Searchin4acj
Got Sand???
you did not tell me you where cutting the roof off, looks bad ass tho, keep up the good work man. we still on for thurs?
Old January 15th, 2008, 08:07 AM   #51
DUNE JUMP
DUNE JUMP's Avatar
Good to see you posting on here jcp
Engine plans include an MSD distributor, Comp Cam and lifter set, Cloyes timing set, and a set of 2.02 valve heads.
Old January 15th, 2008, 08:09 AM   #52
DUNE JUMP
DUNE JUMP's Avatar
yeah, the further into this build I get, the more purpose-oriented it is getting. I don't have any real reason to keep the roof, so off it comes, same with the fiberglass top. I'm still good for Thursday, what time are we talking?
Old January 22nd, 2008, 09:27 AM   #53
DUNE JUMP
DUNE JUMP's Avatar
Default update 1/22/08
The C/Os are mounted! I just have one spring on to simulate approx ride height... Once I do my steering and track bar I can put this puppy on the ground again. Need one more heim for the trackbar.
Progress shots:
SNOW!!
Old January 22nd, 2008, 04:25 PM   #54
Searchin4acj
Got Sand???
almost done, hey the way both of our projects are going, we could go to the mounds next week.lol!!!
Old January 22nd, 2008, 04:59 PM   #55
DUNE JUMP
DUNE JUMP's Avatar
That would be nice, but I still have 80 feet of tube to bend and weld, a track bar to fab, and steering to sort out. Getting the COs mounted was a big step though...
Old January 22nd, 2008, 06:40 PM   #56
Searchin4acj
Got Sand???
ya it looks good
Old January 25th, 2008, 10:03 AM   #57
DUNE JUMP
DUNE JUMP's Avatar
Default progress as of 1-25-08
Track bar is in, tricky though, thanks to Chadwick we got it figured out. Thought I would put it on the ground to give the jack stands a breather.
I'm going to take about 2" of height out of the front, this is just where it stands right now.
Old January 25th, 2008, 01:37 PM   #58
Searchin4acj
Got Sand???
hey i like those tires, that thing looks bad ass
Old January 25th, 2008, 02:10 PM   #59
bigblazer
ditch digger
Looks good!
Assuming you name is true (dune jump), while your working on things check your passanger side rear shock mount. All 6 of our suburbans at work have broke the frame in half there. And my blazer is starting to crack. All the bottoming out on the dunes seems to really stress the mount and frame right there. Id really suck to jump it and have the frame break. I've been thinking about inbording my shocks to solve the problem (in a / \ way) when I buy new shocks but thats as far as I've got.
bigblazer is offline   Reply With Quote
Old January 25th, 2008, 02:29 PM   #60
Strangler
Strangler's Avatar
Why is your trackbar bent? Could you not have moved the frame mount forward so the bar would be just in front of the diff cover?
Page generated in 0.45230 seconds with 84 queries
