'76 K-5 Coilover front end, cage, 468 BBC - Page 10 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 21st, 2009, 07:55 AM   #181
DUNE JUMP
DUNE JUMP's Avatar
Originally Posted by Danza View Post
if I remember right I think you did something different with it??
No, I haven't finished that "flap" yet- probably will do a gusset that bolts to the inside of the frame like this-
The "flap" seems pretty solid as-is, but sometimes I get a little crazy on the dunes, so some extra insurance wouldn't hurt.
Old January 21st, 2009, 08:01 AM   #182
DUNE JUMP
DUNE JUMP's Avatar
Originally Posted by four_by_ken View Post
Did you ever finish up the front suspension? I looked back at the pictures and I dont see the final setup. Did I miss it?
Yeah, the front is all done-- apparantly I took pics of it on the ground before I did the steering, so no pics of everything together. Now I have the arms taken off to finish welding and paint. It does have 1 of 2 fenders on in my defense.
edit: found one pic of the front done, still off the ground, no tires on, suspension at full jounce.
Old January 23rd, 2009, 06:57 AM   #183
DUNE JUMP
DUNE JUMP's Avatar
Default Update 1/23/09
Some updated pics from last night. Sorry about the welding haze...
WOW, what a mess!!
The RH fender needs to be trimmed at the turn signal lens still.
The rear of the fenders will get trimmed to fit the door opening eventually so I can run my door skins. I pulled the hood/fenders back into the cowl about 6" and got rid of the cowl top closeout panel.
Next up I'm going to fab up a front bumper so I can mount my lights and grille.
Thanks to my father in law, I now have a sweet aluminum radiator to put in as well.
Old January 23rd, 2009, 07:10 AM   #184
four_by_ken
Need a strap?
four_by_ken's Avatar
I wanna know more about the front suspension.
four_by_ken is offline   Reply With Quote
Old January 23rd, 2009, 09:30 AM   #185
DUNE JUMP
DUNE JUMP's Avatar
Ok, here's what I've got up front:
Lower arms are 2.5" .25 wall box with 2" sleeved into it. 1 1/4 heims at the frame end, poly bushings at the lower axle end.
Upper arms are 1 3/4 DOM. 1 1/4 heims at link end, poly bushings at the axle end.
Axle brackets are Ballistic Fab ones designed for coil springs, bought them before I got coilovers. Now they make all their brackets water-jetted :)
I ran a track bar to control lateral movement and planned it carefully to minimize bump steer. The upper mount is in line with the pitman arm and the axle mount is as close as I could make it to the drag link pivot on the tie rod. Track bar is 1 3/4 DOM with 1 1/4 heim at the axle and a poly bushing at the top. I had to put a little bend in it to get it to clear the pumpkin at full bump. The whole thought process for the front suspension is low and stable with maximum travel.
Steering is 1 1/2 .25 wall DOM with 3/4 heims and hi misalignment spacers setup to be almost maxed at full droop.
I'm running 14" 2.5 King Coilovers with 350/500 springs. This should put the effective spring rate at ~200 lb/in until the suspension compresses ~ 4" from ride height, then it bumps to the heavy spring (500 lb) to absorb the heavy hits (DUNE JUMPS) .
Im running poly bump stops and limit straps to catch the suspension during the last 2" of droop. Straps stetch, so this is accounted for with the mounting positions.
This will cycle 14" of vertical wheel travel, and the design allows for me to pull the drivers side upper link if I want for crawling to avoid all the binding inherant to a radius arm design when crossed-up.
I'm going to run this for a while and see how it handles, I may end up changing it to a 3-link if it doesn't work the way I planned.
All of the front suspension pics are on page 1 of this thread.
Old January 24th, 2009, 10:26 AM   #186
Searchin4acj
Got Sand???
Searchin4acj's Avatar
Send a message via AIM to Searchin4acj
looking good
Searchin4acj is offline   Reply With Quote
Old January 27th, 2009, 07:06 AM   #187
DUNE JUMP
DUNE JUMP's Avatar
thanks bud-
I got out there for an hour last night and actually got my heater to work
I've been working on bumper idears, and realized I need a method of bending sheet metal that doesn't involve a hammer and a vise. I know harbor freight has a 30 dollar brake, but it uses c-clamps and looks pretty weak. Plus, I have a lot of odds and ends of steel scrap just waiting to be put to use, so I fabbed this up. It's pretty booty-fabulous, but gets the job done. I would score it a BF-2
It's not done, but it is functional and serves it's purpose.
Old January 27th, 2009, 09:36 AM   #188
Searchin4acj
Got Sand???
What guage sheet metal are you looking to bend i have acess to two breaks thats how i am bend my sheet metal. let me know and i could prob bend it up for you.
Old January 27th, 2009, 09:51 AM   #189
DUNE JUMP
DUNE JUMP's Avatar
cool man, I may hit you up for that-- It's like 3/16 mild, so nothing too crazy. I may even make up a couple bending dies to use in my all-pupose bottle jack press
Old January 27th, 2009, 10:11 AM   #190
Searchin4acj
Got Sand???
thats cool i have a 40 inch break here but the most i couls bend on it is like 18 i think
Old January 27th, 2009, 11:55 AM   #191
VonDirt
VonDirt's Avatar
Originally Posted by DUNE JUMP View Post
thanks bud-
nawh - thats a "one" - if that
nice work, its looking good
VonDirt is offline   Reply With Quote
Old January 27th, 2009, 12:37 PM   #192
Jb1986
Bowtie boy
Jb1986's Avatar
sweet k5 i had 3 k5s but none as nice as urs
Jb1986 is offline   Reply With Quote
Old February 2nd, 2009, 09:45 PM   #193
DUNE JUMP
DUNE JUMP's Avatar
thanks guys
side note- since it was warm Sunday we took the kids out, and the girls got to go offroading in their stroller. Daddy couldn't help it. It did well since it's a dually :)
Gotta start them out early!
Old February 6th, 2009, 06:44 AM   #194
DUNE JUMP
DUNE JUMP's Avatar
Default Update 2/6/09
Ok, back to work on this beast. I have a new source of steel plate the side steps off the military tug truck are 3/16, and cut like butter with the plasma. I love the OD green
The box tube is 2.5" .25 wall, so it will make a good base for recovery points and someday... a winch
The plan is to trim up the fenders, then do some recycling with the old front bumper (cut off all old tubes and clean up) and use the main tube as the base of the new bumper and span the distance between the fenders. This will give me somewhere to mount lights and the grille.
I also need to build a new radiator mounting system for my new radiator, and new fan mounts to go with it.
Old February 16th, 2009, 06:42 AM   #195
DUNE JUMP
DUNE JUMP's Avatar
Default Update 2/16/09
I spent an hour fabbing up what I thought would be a cool one-piece grille suround, headlight bezel piece, then I set it up front and hated it. Went up in the attic and got my grille and trim piece down, set it up there and thought it looked pretty decent. I tabbed the front to the fender/hood supports, and drilled the fenders for the lower attach points. Still have room for the Hella 4000's in the headlight openings, and still will probably make some trim pieces to fill in around the lamps.
I realize now that I need to get some more tubing and get that bumper fabbed up. I like how it's coming along though.
Old February 16th, 2009, 08:27 AM   #196
VonDirt
VonDirt's Avatar
[QUOTE=DUNE JUMP;1533647]I spent an hour fabbing up what I thought would be a cool one-piece grille suround, headlight bezel piece, then I set it up front and hated it. QUOTE]
i think the culprits are still sitting on the hood
seriously though, its looking good - are the 4k hella's those big ass ones, not deep but large dia ?
Old February 16th, 2009, 08:38 AM   #197
DUNE JUMP
DUNE JUMP's Avatar
[QUOTE=VonDirt;1533803]
i think the culprits are still sitting on the hood ?
---You mean these ---
Thanks
Yeah the 4000's are 9" diameter, not too deep, except in the middle they're probably 6-8" deep. I have the euro beam ones, so they have a nice flat output, no pencil beams for me.
I'm going to use some of my failed grille surround to make the headlamp bezels, should work out well. I'm just trying to keep the front [light] and simple.
Old February 16th, 2009, 08:46 AM   #198
mtxbigtruckin
Wheelin' Since Birth
mtxbigtruckin's Avatar
Too bad that thing ain't ready yet! Sno Blind this weekend!
mtxbigtruckin is offline   Reply With Quote
Old February 16th, 2009, 08:52 AM   #199
DUNE JUMP
DUNE JUMP's Avatar
how many open top rigs usually run it?
Old February 16th, 2009, 08:54 AM   #200
mtxbigtruckin
There have been a few, don't be a sissy, throw a coat on and some heat and run in the snow!
Page generated in 0.66410 seconds with 84 queries
