Project tug cj-10a now going full rock crawler - Page 5 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 29th, 2008, 11:11 AM   #81
jaymcjay
jaymcjay's Avatar
Originally Posted by pokerob View Post
New pics, almost ready to offroad,
things i need to finish are the
1. B&M shifter
2. Kickdown linkage
3. Rollbar (more trianulation)
a few other misc things i cant think of right now.
I dig the monster articulation of this thing. How did you get all that flex? You're going to design my next suspension you rok-god!
jaymcjay is offline   Reply With Quote
Old May 29th, 2008, 12:25 PM   #82
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Missing front bumper...destroyed in a freak offroad camper accident? :tonka: Lookin' good, Rob!
Craig
Old May 29th, 2008, 01:09 PM   #83
revho
$9.00 vanilla malt
revho's Avatar
Craig
ahahahaha
revho is offline   Reply With Quote
Old May 29th, 2008, 01:49 PM   #84
Pokerob
hug life
Pokerob's Avatar
Craig
Originally Posted by revho View Post
ahahahaha
:tonka:
i took the bumper off previous to the "incident", so
basically i raw dogged him with my frame :tonka:
dics
Old May 29th, 2008, 02:03 PM   #85
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
The problem with the carb sounds like a float issue, either its sticking or out of adjustment.
Old May 29th, 2008, 02:21 PM   #86
Pokerob
hug life
Pokerob's Avatar
when i took it apart i had it running for awhile...
i took the top part of the carb off first (while still on jeep) to see the float level...that was good...
the float may be sticking but i have a rebuild kit comming,
so that may take care of some issues too..
NOTE: it runs better now that i found a vacumm leak, but it still seems like the timing is off just alittle bit but its not..
Old May 29th, 2008, 02:31 PM   #87
jeepfreak81
81 inches of fun
Try getting some Indian Head gasket sealer (small brown bottle, white cap) and use it on the base gasket of the carb, it is the only thing I have had luck with when sealing up the base gasket. You still may be sucking a little air there. I had to use it on ALL the carb gaskets on my dad's '73 Buick (also a Rochester 2G) to get it to quit sucking air at the gaskets. It is nasty stuff and doesn't come off for anything, so make sure you have all your settings right as far as float level etc... before you use it, as it will ruin the gasket if you have to take it back apart.
My float was set to spec (1" for my Rochester 2G) and It was still overflowing into the cylinders, I had to adjust it to put a little less fuel in then spec said and my issue went away and the engine still runs great.
Mine was flooding so bad that raw fuel would come out the drivers side glass pack. (225 V6 in the flattie)
Old May 29th, 2008, 06:27 PM   #88
supervaughncj8
KaBloughy
supervaughncj8's Avatar
Dude, how did you get on top that log?
supervaughncj8 is offline   Reply With Quote
Old May 29th, 2008, 06:37 PM   #89
jaymcjay
jaymcjay's Avatar
locked in low range, I bet. I was wheeling out there before but I didn't want to bust up my rig so I took the bypass around that obsticle. :tonka:
Old May 29th, 2008, 07:22 PM   #90
supervaughncj8
KaBloughy
Really thou, it does look good Rob
Old May 29th, 2008, 07:30 PM   #91
1x1_Speed_Craig
Simplify...
Rob - It looks like you're starting to graft a stamped upper tub edge on the bed (driver side looks done). That'll make the whole setup look 100% better.
BTW, regarding the "dics" comment..."With friends like us...".
Craig
Old May 29th, 2008, 07:41 PM   #92
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
that is some MAD flex
Old May 29th, 2008, 08:59 PM   #93
jaymcjay
jaymcjay's Avatar
:tonka: i did have to put a little log behind the back tire though so it wouldnt roll off
r u saying i need better axles / engine / tranny / suspension / rims / tires ??
cause i would agree,
again....
dics
I've got a chevy 350, 700R4, NP241 t-case, HP Dana 44 front and matching 9" with your name on it buddy! You've just got to swing by and pick it up (oh, and pay me too...)
Old June 1st, 2008, 07:43 PM   #94
Gunsworth
Gunsworth's Avatar
were you at silver lake mem day weekend, think I saw ya
Old June 2nd, 2008, 08:17 AM   #95
Pokerob
hug life
Pokerob's Avatar
unfortunately no,
Tugly has a series of runability issues up to this point,
but hopefully silverlake is in its future before the summer is over.
Old June 2nd, 2008, 03:32 PM   #96
thrill20
thrill20's Avatar
shoulda bought/built a toy.....
j/k. looks good
thrill20 is offline   Reply With Quote
Old June 2nd, 2008, 03:40 PM   #97
Pokerob
hug life
Pokerob's Avatar
j/k. looks good
ya lost me...
but thanks
Old June 2nd, 2008, 09:54 PM   #98
thrill20
thrill20's Avatar
A sweet toyota like this.........
BTW, I finally got the other wheel off..... now they all match.
Old November 30th, 2008, 03:17 PM   #99
Pokerob
hug life
Pokerob's Avatar
Highsteer is done,
The HS arms and TRE's are really close to the tires though.
I may need to buy new rims with a different offset.
Old December 1st, 2008, 02:50 PM   #100
Pokerob
hug life
Pokerob's Avatar
a few more shots of the tailgate chopped and bb sticker
Page generated in 0.43566 seconds with 84 queries
