Why not use the 10.25 sterling - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 4th, 2006, 05:58 PM   #1
Gunsworth
Gunsworth's Avatar
Default Why not use the 10.25 sterling
if its supposedly stronger than a d60 why dont more people use it?
Is it that much more of an anchor?
Also would it be rediculous to run one with 35s?
*edit, Sorry for being a newb and posting this in general tech, I always forget about the axle section, thanks for the relocation*
Old March 6th, 2006, 06:02 PM   #2
Perhaps limited availability of gears and lockers, comes to mind for me...
Old March 7th, 2006, 04:23 PM   #3
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
that was the case for a long time, but it's starting to change now. the big downfall of them from '99 up is the metric bolt pattern if you don't have the matching d50/60 front. There was also a semi floating version availble also....so just watch which one you get.
Old March 7th, 2006, 05:28 PM   #4
Gunsworth
Gunsworth's Avatar
well mine is a 92 so I believe it is ff. Assuming it is I guess I will just drag it around with 35s till I go bigger
Old March 7th, 2006, 06:08 PM   #5
Aren't there some wierd 7-lug versions from F-150s with the 7700 package?
Old March 8th, 2006, 07:30 AM   #6
Icebreaker88
Icebreaker88's Avatar
I seen some 7 lug axle shafts at work but did not see what housing they were going in.
I think it might be the 9.75 but not sure.
[QUOTE=TurdBronco;1095911]I don't usually race cause it is still a focus.[/QUOTE]
Icebreaker88 is offline   Reply With Quote
Old March 8th, 2006, 09:17 PM   #7
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Yep I believe it was the 9.75 axle.
I didn't realize they made the 10.25/10.5 in SF until my buddy bought a 89 f250.....with a semi floater sterling. Of course that truck only had a factory 302ci.
Old March 9th, 2006, 12:22 AM   #8
PavementPounder
PavementPounder's Avatar
I drag my D70 around with 37's and its smooth on the bottom. 35's would suck ass.
Old March 21st, 2006, 04:08 PM   #9
scramblerman72
Moonlight stomper
scramblerman72's Avatar
Send a message via AIM to scramblerman72 Send a message via MSN to scramblerman72 Send a message via Yahoo to scramblerman72
Cus a 14 bolt is way easier to find and the cheapest to build and the easiest to set up!
scramblerman72 is offline   Reply With Quote
Old December 6th, 2006, 10:41 PM   #10
Jrod-13
poser wheeler
there is nothing wrong with a sterling, the ground clearance is actualy about the same as a 60. and the aftermarket was miles ahead of a 14bolt(14 bolts just recently got a selectable locker) sterlings also have gearing as low as 7.17
Jrod-13 is offline   Reply With Quote
Old December 7th, 2006, 09:20 AM   #11
xj_man_646
Wheeler-less
xj_man_646's Avatar
Send a message via AIM to xj_man_646
no, that was on 1999 f250's that had an f150 body, must have been right at the beginning of their change to the new body style. buddy of mine has one with 7 lugs, goofy mofo.
edit: or maybe it was an f150 with a f250 badge and 2 more lugnuts, i'm not sure...but it looks like an f150 in all aspects except for the lugnuts and possibly rear axle, but i haven't looked at the rear end in the thing yet.
xj_man_646 is offline   Reply With Quote
Old December 21st, 2006, 08:06 PM   #12
redmud
10 0011 10101
redmud's Avatar
I saw one o' them 7 lug f-250's this week. I had to stare at it for a few minutes before i figured out that it had 7 lugs. It was a '99 F-250 that was the F-150 body style. weird.
redmud is offline   Reply With Quote
Old December 21st, 2006, 09:06 PM   #13
badazzamc
Get Some
badazzamc's Avatar
7 lug? i have never seen anything like that.
Old December 22nd, 2006, 08:17 AM   #14
redmud
10 0011 10101
redmud's Avatar
I've only seen the one, and it was a 250 that had the 150 body.
Page generated in 0.32648 seconds with 65 queries
