Trans slipping? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 24th, 2007, 08:21 PM   #1
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Default Trans slipping?
It hesistates, gear hunts, slips and shifts hard but only from little to maybe 1/3 throttle. Past that, it shifts nice and crisp and there are no issues.
This leads me to believe it's the TPS again, but I'm not positive. It really feels like a TPS issue.
Thoughts?
'01 Dodge Ram 4x4 5.9L 46RE
Old September 24th, 2007, 08:25 PM   #2
EL BURRO
33's is how I roll
EL BURRO's Avatar
how many miles, what maint. has been done to the tranny?
EL BURRO is offline   Reply With Quote
Old September 24th, 2007, 08:38 PM   #3
GreaseMonkey
Pew pew!
72,400 miles.
Tranny has been flushed once around 40,000 miles, and flushed in the last couple hundred miles with a new filter and ATF +4 put back in.
Fluid level is correct. Other than that nothing else has been done to the trans.
Old September 24th, 2007, 09:12 PM   #4
Smiley23
Smiley23's Avatar
Did you put trans conditioner in? NOT the trans "sealer" and conditioner - just conditioner. Stay away from the sealer (IMO).
Smiley23 is offline   Reply With Quote
Old September 24th, 2007, 09:24 PM   #5
GreaseMonkey
Pew pew!
No.
Old September 25th, 2007, 04:14 PM   #6
GreaseMonkey
Pew pew!
I threw a new TPS on there and it seems to have corrected the problem.
Old September 25th, 2007, 05:34 PM   #7
badazzamc
Get Some
badazzamc's Avatar
thats about the same milage that i had to put a trans in my dodge.
Old September 25th, 2007, 08:53 PM   #8
GreaseMonkey
Pew pew!
New TPS didn't fix it.
I reflashed the PCM and there's no P code.
Fawkin' Dodge.
8,000 more miles and my powertrain warranty is up.
Old September 25th, 2007, 09:28 PM   #9
user name
keep your stick onthe ice
user name's Avatar
that time with the dented pan could have hurt it a bit.
Old September 25th, 2007, 09:29 PM   #10
Mclovin
"The Situation"
Mclovin's Avatar
Fawkin' Dodge.
So take it in ? Let them fukc with it..
Old September 27th, 2007, 07:19 PM   #11
SS
Bananarama!
SS's Avatar
What have you got to lose? Dump in a bottle of Lucas No-Slip. Worked wonders on my Dodge and that thing lived a very hard life
It's $7. Just try it.
-Jer
Old September 27th, 2007, 07:46 PM   #12
GreaseMonkey
Pew pew!
Already did. No luck.
Got an appointment at the stealership Monday.
Have to tow the motorcycle home this weekend.
I noticed something kind of odd. With the increased load on the motor with the trailer, the trans stopped "slipping." That paired with the additive not working makes me think that possibly the MAP or some other sensor the trans uses to control shift points is starting to go.
Old October 3rd, 2007, 01:40 PM   #13
GreaseMonkey
Pew pew!
Got it fixed at the dealer. Ended up being some pressure sensor/switch.
Old October 3rd, 2007, 11:55 PM   #14
scottie
Eye candy
scottie's Avatar
its a chrysler trans, they are all garbage
or very high maintenance.
Old October 4th, 2007, 12:23 AM   #15
GreaseMonkey
Pew pew!
Not all.
This is the first issue I've had with the trans and there is 73,000 miles on it.
Old October 4th, 2007, 09:08 AM   #16
Tom
Because racecar
Tom's Avatar
governor pressure solenoid .......very common
Old October 4th, 2007, 09:22 AM   #17
GreaseMonkey
Pew pew!
Yup, that was it. They replaced something else too under the warranty. I'll post up what it all was when I get the truck back today.
Old October 11th, 2007, 10:53 AM   #18
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
Not all.
you can not argue that at all, they all suck and have issues
Old October 11th, 2007, 11:31 AM   #19
kickstand
circling the drain
kickstand's Avatar
Not all.
ummmm I have 100,000 miles MORE then you and my trans is fine.
Its a dodge trans, its junk.
Old October 11th, 2007, 02:21 PM   #20
user name
user name's Avatar
I know everyone thinks they are junk but really dodge a trans last just fine if you change the fluid and adjust the bands when they are suppose to. I like to think of it this way the 700r4(now 4l60e) came out in 82 and was a shitty trans until about 93 thats 11 years. The 518(turned into 46re) came out in 90 and was already an ok trans buy 93. If dodge is on the same plan as GM the 01 and up trans should be a pretty good unit. I personally think dodge got the O.D. program together a lot quiker than GM or Ford everyone just bitches whenever a dodge trans fails and dont really talk about the other brands failings.
Page generated in 0.37704 seconds with 83 queries
