Motorhome guru's? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 23rd, 2007, 09:03 PM   #1
Icebreaker88
Icebreaker88's Avatar
Default Motorhome guru's?
I am going to go look at a class C motor home this week. Just curious on how well this would tow a 7klb trailer. It is a 87 25' Jayco on a Ford chassis with a 460 in it. Also has about 95k miles on it. Just form pic it looks like it is in great shape and was stored indoors
Thanks for any input.
[QUOTE=TurdBronco;1095911]I don't usually race cause it is still a focus.[/QUOTE]
Icebreaker88 is offline   Reply With Quote
Old September 24th, 2007, 07:21 AM   #2
My last motorhome was a 94, 22ft Jayco with the same engine. It probably has 4.10 gears in it.
Mine towed fine other than I had trans overheating problems in the mountains while going slow. Higher speeds were fine.
Figure on 6mpg towing the trailer, 8-9 empty.
If that is where your budget is at, go for it.
Old September 24th, 2007, 07:28 AM   #3
PurpleRhino
PurpleRhino's Avatar
I am a Jayco dealer and that MH was rated to tow 7500 pounds when new. You will be at the upper part of your towing capacity. As long as the drivetrain is still in good shape you should be ok. Just be smart and use weight distributing hitch equipment.
PurpleRhino is offline   Reply With Quote
Old September 24th, 2007, 11:29 AM   #4
Icebreaker88
Thanks for the info. Yeah I dont mind the mileage just want to make sure something like this could tow my car hauler with the Bronco on it at least 65 mph
Old September 24th, 2007, 11:31 AM   #5
ridgerunner
ridgerunner's Avatar
I considered buying a class C when I was in the market a couple of years ago, but after doing some home work, I chose a class A. It just has some much more towing ability than a class C Do to a much higher GVWR.
I have the 460 in mine and get around 6-7mpg fully loaded, while towing around 7000 lbs. I would bet that there is some great deals right now.
good luck with the shopping.
ridgerunner is offline   Reply With Quote
Old September 27th, 2007, 10:26 PM   #6
kb8ymf
Not as old as Whiterhino
kb8ymf's Avatar
You mean like this one!
http://www.greatlakes4x4.com/showthread.php?t=57551
Just filled it up and got 10.1 mpg towing a car hauler back from Colorado.
Gets 7-8 towing with Tracker on flatbed.
jim-kb8ymf
kb8ymf is offline   Reply With Quote
Old September 28th, 2007, 07:22 AM   #7
jim-kb8ymf
Yeah but the interstates require that you drive more than 40 mph.
Old September 30th, 2007, 05:22 PM   #8
kickstand
circling the drain
kickstand's Avatar
So is it rated at less then 7500 now that it isn't new?
How many days until it is rated at 0lbs and he will have to stop towing.
Old September 30th, 2007, 05:34 PM   #9
silverxj
Recovering XJ owner
silverxj's Avatar
I was thinking the same thing ... crap, if this is the same principle I should use with my Dodge I wonder if I gained any towing capacity by putting in a "new" trans??
Page generated in 0.39132 seconds with 50 queries
