14bolt w/ stock brakes will 15" wheels fit? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 4th, 2006, 11:28 AM   #1
prostock3
gimmie gimmie more
Send a message via AIM to prostock3
Default 14bolt w/ stock brakes will 15" wheels fit?
someone please let me know today if 15' wheels will fit on a 14bolt corp. w/ stock full size brakes?
prostock3 is offline   Reply With Quote
Old March 4th, 2006, 11:51 AM   #2
Thebigchev
I've got big balls
Thebigchev's Avatar
Yes they will but if you have the matching frontend they will not fit on that unless you grind the caliper.
Thebigchev is offline   Reply With Quote
Old March 4th, 2006, 12:22 PM   #3
Bones
Bones's Avatar
yup, I can show you how much I had to grind on my caliper if you come over.
EDIT- he has stock discs, not drums....
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old March 4th, 2006, 12:28 PM   #4
Thebigchev
I've got big balls
Thebigchev's Avatar
ENJOY! grinding for a couple of hours.
Old March 4th, 2006, 12:50 PM   #5
prostock3
gimmie gimmie more
will they fit also if you have a Dana 60 front with stock brakes or do you have to do soemting different? also the rear axle has stock disc brakes
Old March 4th, 2006, 12:56 PM   #6
Thebigchev
I've got big balls
Thebigchev's Avatar
NO! You'll have to grind both or which I do not recommend, buy some washers and slip them over the studs if they are long enough. Then that will offset the rim so they stop rubbing.
Old March 4th, 2006, 01:22 PM   #7
prostock3
gimmie gimmie more
ok thanks, didnt mean to upset you
Old March 4th, 2006, 01:50 PM   #8
Thebigchev
I've got big balls
Thebigchev's Avatar
SORRY! I didn't mean it like that. How wide are those rims?
Old March 4th, 2006, 02:54 PM   #9
Bones
Bones's Avatar
about 9" wide after the beadlocks, but only 3.5" BS so they stick way out. I currently run these on my 44 front and 14 bolt rear with D44 disc brake conversion, but prostock wanted to know how much gridning he would need for a D60 front and a 14 bolt rear with stock discs...
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old March 4th, 2006, 03:01 PM   #10
k5jess
k5jess's Avatar
I had to grind for about 4-5 hrs to get my 15" to fitt on my 44.. Thats why I'm going to 16 or 16.5's for when my 60 is done
k5jess is offline   Reply With Quote
Old March 4th, 2006, 03:05 PM   #11
Bones
Bones's Avatar
it all depends on the offset. These rims have a small offset, so they fit over calipers easier.
Come take a look at mine to give you an idea of how much material has to be removed. I probably spent less than 30 min on each caliper....
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old March 4th, 2006, 03:06 PM   #12
Thebigchev
I've got big balls
Thebigchev's Avatar
It took me about 2 hours to do a frontend. You have to grind put the tire back on tighten up 2 lugnuts oppisite of each other and then spin the tire until it spins freely. I had to do it 10 times on each side. You might not have to do it that much if your offset away from the axle is good thats all it really depends on.
Old March 4th, 2006, 03:09 PM   #13
Bones
Bones's Avatar
lol, I just grinded the hell out of it and tried it at the end... saved time of putting the tire on and off 10 times (that would take me 30 min per caliper of just putting the tire on and off)
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old March 4th, 2006, 03:12 PM   #14
Thebigchev
I've got big balls
Thebigchev's Avatar
Yeah I was kind of worried about taking to much off it was a daily driver.
Old March 4th, 2006, 05:01 PM   #15
Bones
Bones's Avatar
this was how much I had to grind
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old March 4th, 2006, 05:02 PM   #16
Bones
Bones's Avatar
and
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Page generated in 0.39109 seconds with 72 queries
