dana44 hub bearing torque??? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 21st, 2007, 03:02 PM   #1
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Default dana44 hub bearing torque???
How much torque do you put on the lock ring .... it tightens up against the pre-load ring..
I have seen 150-ftlbs.
I did this to the driver side, spins great, no problems.
However I did this to the passanger side and I striped the threads on the spindle Good thing for a spare axle laying on the side of the house.
I could only get it tight to about 50-ftlbs. If i go anymore I can't turn the damn thing. Pre-load is correct. I torque to 50-ftlbs. than back off 1/4 turn.
Bearings look good to.
Old September 21st, 2007, 03:48 PM   #2
shawn
Resident HVAC/R Jambi
shawn's Avatar
I think it is also 50 lbs.
Old September 21st, 2007, 03:51 PM   #3
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
i have actually seen it go from 50-200 by some people.... I can't imagine doing 200!!! 150 was a biznitch to do! I will just leave it 50 on the passanger side, 150 on the driver side. haha
or should i do them both at 50??? I don't want bearing failure
Old September 21st, 2007, 03:59 PM   #4
Sandals
Fucking Zen as Shit
Sandals's Avatar
I generally tighten to pretty tight with a 1/2" drive ratchet and then back it off.
Always seems to work well probally ends up between 50 and 100 ft/lbs
For stuff like that, which you may need to fix on the trail, i always try to figure out not the numerical amount, but what it feels like with the tool for tightness
Old September 21st, 2007, 04:56 PM   #5
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
spec is gud-n-tight
Old September 21st, 2007, 05:35 PM   #6
PavementPounder
PavementPounder's Avatar
Both at 50. The high numbers you are thinking of are for unit bearings.
Old September 21st, 2007, 05:48 PM   #7
Sandals
Fucking Zen as Shit
Sandals's Avatar
Originally Posted by 99grandtj View Post
spec is gud-n-tight
finally someone agrees with me
Old September 21st, 2007, 10:04 PM   #8
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
50 then back off quarter turn is correct.
Old September 22nd, 2007, 11:05 PM   #9
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Service manual says the inner nut goes to 50 foot pounds while rotating the hub. Then back it of, then to a final of 35 foot pounds.
The outer nut goes to 50 foot pounds.
Many people/manufacturers do it other ways. Toyota 8"s require you to check rotational drag with a scale, which IMHO is a better way.
JcrOffroad
Zoom Zoom!
Old September 26th, 2007, 01:16 PM   #10
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
hot damn than i better check on the other side to make sure its not to tight!
Thanks monkeyevil!
yes doing it by drag would be nice, but for the mor than average person, we don't have the stuff to do it.
Old September 26th, 2007, 09:24 PM   #11
scottie
Eye candy
scottie's Avatar
Thanks monkeyevil!
It usually just a spring scale.
Page generated in 0.24298 seconds with 56 queries
