valve noise??? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 21st, 2007, 09:41 AM   #1
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
Default valve noise???
have a 85 honda shadow 700......yesterday i got it out for a ride and it was ticking.....so i stopped and found it was coming from the rear cylinder on the top end.....i pulled the seats, gas tank, etc to get to the valve cover....pulled it and the valves all seem to be tight nothing loose in there.....right next to it is the timeing chain for the cam....under another cover of course and i cant get it off.....so we started it up to see if it was the valves and the looked and sounded fine but the noise sounded like it was still comeing from that maybe the timeing chain area......any thoughts on what it might be??
'09 "Sparkly Tan" Jeep Patriot
http://badges.fuelly.com/images/smallsig-us/306663.png
CLICK HERE TO GET RID OF ME
Originally Posted by PCK_4xCustoms View Post
cunt punt, it's like a reset switch for women.
sQUEAK003 is offline   Reply With Quote
Old September 21st, 2007, 08:15 PM   #2
bikerted86
Either the timing chain is loose or you have a collapsed lifter, I belive there are 3 lifters per cylinder, I rebuilt the top end in one of those last year and it had 2 bad lifters.
bikerted86 is offline   Reply With Quote
Old September 22nd, 2007, 11:14 PM   #3
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
k.....ill check that again.....it looks liek the cam rides right on the rocker and the valve rides right on the valve though......i gotta pull the motor to pull it apart farther though
Old September 23rd, 2007, 06:46 PM   #4
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
how much did that run ya for parts??
Old September 24th, 2007, 01:48 PM   #5
bikerted86
i dont remeber how much but the lifter pushes on the rocker pivot it has a cam cut in one spot and there is also some small springs.
Old September 26th, 2007, 01:04 AM   #6
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
im confued.....when i pulled the valve cover and looked in there i didn't see any of that......the cam that the timeing chain is hooked to has the rockers rideing right on it......which push directly on the valves......where are these lifters ur talkin about
Old October 3rd, 2007, 07:24 PM   #7
bikerted86
the lifters are under where the cam rests there are 2 parts to the cylinder head, they push on a cam which is the rocker pivot you cant get to them without pulling the cam out of the bike.
Old October 6th, 2007, 10:50 AM   #8
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
k....i guess im pulling the cam then.....either way the only way to get the head off or apart is by pulling the motor out of the bike.......damn honda frame
Old October 6th, 2007, 06:45 PM   #9
bikerted86
yep that ones not too bad the right side of the frame should unbolt.
Old October 9th, 2007, 03:27 AM   #10
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
yeah......why did they make the frame like that......for ease of pulling the motor??
Old October 23rd, 2007, 06:57 PM   #11
bikerted86
yeah otherwise you would never get it out, get a friend to help i got that one out myself but i ripped a pair of pants in the process
Old October 29th, 2007, 06:07 AM   #12
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
i haven't even looked at the bike in weeks......i gotta get the motor in the jeep first....its now my dd.....bike will come after that.....u obviously do this for a living.....what shop do ya work for if im correct in saying u do it for a living
Old January 3rd, 2008, 07:24 PM   #13
bikerted86
i do it for a living on weekends, I work a freds bikes and trikes in livonia. Im actually rebuilding a 1100 thats exactly the same thing
Old January 5th, 2008, 06:31 PM   #14
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
i think i might just pull it all apart when i get the motor out and go through everything.....the guy i got it from said it was a fresh rebuild and i believed him cause all of the gaskets wer white and looked brand new
Old January 16th, 2008, 07:08 PM   #15
bikerted86
get a dealer repair manual and make sure the lifter shims are right when you do it if he didnt know about them he could have turned that cam holder upside down and dumped them on the floor and put them back in wrong. There is usually 2 per lifter.
Page generated in 0.32568 seconds with 68 queries
