1984 D350 No Start Problems - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 20th, 2007, 06:28 PM   #1
deuce228
Redneck Poser
deuce228's Avatar
Default 1984 D350 No Start Problems
All the sudden the truck shuts off. Try to start it will fire right up until you let go of the key. Then it shuts off.
Ballast Resistor Changed.
Coicidence perhaps but happened at the same time the lights were being dimmed.
Old September 21st, 2007, 07:02 AM   #2
deuce228
Redneck Poser
deuce228's Avatar
Top. Could use some help.
Old September 21st, 2007, 09:48 AM   #3
bigjeep65
Lurker
bigjeep65's Avatar
Engine? Assuming 360 gas. Single coil ballast (1 plug each end) or dual coil (2 plugs each end)? Dimmer switch on column?
First thought would be ignition switch. Coil should have power in both run and start key position. I would start there and work backward. Quite possible you have a shorted fusable link in the wiring.
bigjeep65 is offline   Reply With Quote
Old September 21st, 2007, 09:54 AM   #4
deuce228
Redneck Poser
deuce228's Avatar
Engine is a 360.
I didn't do the ballast, my father did, so I don't know if its single or dual. Dimmer switch is the floor. Again not sure if its related to the mess or not.
Someone mentioned the coil could be bad, and only getting enough with the 12 volts in teh crank position??
Old September 21st, 2007, 11:29 AM   #5
bigjeep65
Lurker
bigjeep65's Avatar
Originally Posted by deuce228 View Post
Engine is a 360.
Dimmer switch may not be related (probably isn't). If you have access to a volt meter, start checking current backward from the coil.
Eliminate the easy checks first. Do all other electrical items work?
Old September 21st, 2007, 12:16 PM   #6
deuce228
Redneck Poser
deuce228's Avatar
it is an old dodge. really not much for electronics there. lol
We will go thru it.
Thanks
Old September 21st, 2007, 12:23 PM   #7
user name
keep your stick onthe ice
user name's Avatar
not that this is all that helpful but have you considered an msd box and coil?
Old September 21st, 2007, 12:27 PM   #8
deuce228
Redneck Poser
deuce228's Avatar
No. I am just looking for our work truck to be running again. I don't even know the benifits of it.
Old September 21st, 2007, 03:47 PM   #9
user name
user name's Avatar
the 2 big benefits are supposed to be better fuel economy and improved performance at all rpms. I haven't run one myself yet but the people i know that have it seem to love it for the most part. That and I am not a fan of the stock Dodge ignition msd would get rid of most of it. I see were your coming from and i would probably fix what is has to.
Page generated in 0.34238 seconds with 50 queries
