Teardrop trailer project - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 17th, 2007, 01:51 PM   #1
JEEPR
Playing Possum
JEEPR's Avatar
Default Teardrop trailer project
This isn't a vehicle project, but it is something that is outdoor related. A teardrop camper is a small hard sided trailer that can easily be towed by a Jeep or other small vehicle. Depending on what kind of suspension you install, it can be used offroad also. There is generally a sleeping area up front and the galley is outside, accesses through a rear hatch.
I based mine on a set of plans in a 1947 Popular Mechanics article. Most of these are 4'x8'. Mine is just shy of 5'x10', because I wanted more room. Mine has almost a queen size bed, cabinets at the head of the bed, cabinets over the foot of the bed, an under floor storage area, and the galley. It should weigh just over 1000 pounds.
I actually plan on making the cover for the floor storage a table, so you can put the table up, put your feet down in the storage area, and sit and eat.
here is the trailer we welded up 2" square tubing, 4" square tongue.
Home Depot loves me.
Frame built, 2x4 and 2x3s.
floor built, that hole is where the storage will be. The floor has 1.5" of insulation.
The floor upside down and coated with roofing material.
The walls cut out and mounted.
Here is the front closet area. There will be doors on the lower holes. Shelves on the left and hooks on the top of the right. The three holes at the top will remain open and just be storage.
I am building this to have something dry and up off of the ground to camp in, that I can pull with my TJ, so I don't have to tent it. I have tried pop-ups and thought this would be more fun.
Here is it's current state of construction as of 10/05/08
JEEPR is offline   Reply With Quote
Old September 17th, 2007, 02:22 PM   #2
Kawierider
Kawierider's Avatar
very cool. Looks like a hell of a good project. do you have alot of woodworking expereince?
I'd shackle up those springs and put tires on it to match the jeep.
what are your plans for siding/roofing ?
Old September 17th, 2007, 03:00 PM   #3
Bones
Bones's Avatar
hmmm, cool idea, keep taking pics of everything
can you keep a tab of how much $$ you have into it? I would be curious to see what you have into it at the end...
oh, and weight it when you're done too.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old September 17th, 2007, 03:15 PM   #4
gotsand?
sie sehen mich rollin ...
gotsand?'s Avatar
Location: New Era, MI --- "We passed BFE 35 minutes ago."
Send a message via Yahoo to gotsand?
x2
looks like it will be sweet!
gotsand? is offline   Reply With Quote
Old September 17th, 2007, 03:17 PM   #5
Dave Kerwin
web wheeling, hard.
Dave Kerwin's Avatar
keep up the good work!!
Old September 17th, 2007, 03:17 PM   #6
JEEPR
Playing Possum
JEEPR's Avatar
Not really, but I have done a little of everything, like framing doors, building a bar, refinished my basement, etc.
I have thought of matching up the Jeep wheels.
Roof will be 1/4" ply covered with sheet aluminum. Sides will be epoxy marine paint.
Bones So far I have about 500-600 into it with building the trailer, screws, glue and wood. I haven't gotten any hardware or aluminum (trim, latches, roof cover, etc.), I am aiming for around 2 grand total.
Old September 17th, 2007, 04:20 PM   #7
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Nice-looking project. Just out of curiousity, did you use treated wood on the underside? All of the 2x4s look like standard studs (untreated). If so, how will you seal the underside? Is that what the roofing sealer does?
Craig
Old September 17th, 2007, 04:23 PM   #8
One Arm Steve
I was born in the desert
One Arm Steve's Avatar
Nice work!
One Arm Steve is offline   Reply With Quote
Old September 17th, 2007, 04:50 PM   #9
JEEPR
Playing Possum
JEEPR's Avatar
Craig
No treated wood, the bottom skin is moisture resistant luan, top is 1/2" flooring plywood. It is all sealed with roofing material. I looked into covering the bottom with aluminum. Everything I read said not to, the skin traps moisture and makes the wood rot. Hopefully with everything sealed, caulked, and glued together, no water will get in there. The insulation is closed cell styrofoam, so hopefully dryrot won't be an issue.
One thing I like about building it myself, I know how it's put together. If the wooden frame rots, I will cut it out and replace it with treated lumber. I don't think I will have a problem though. I overbuilt my frame, a lot of them don't even have frames and just use a 3/4" piece of plywood for the floor. I did the frame so I could insulate, just in case I camp a weekend like we had during the Pig Gig...
Edit: Here is a scan of the 1947 article I (losely) based my design from. It's in Adobe format http://www.tinytears.cc/Scans/Trailer%20For%20Two.pdf
Old September 17th, 2007, 05:41 PM   #10
BRUSER
BRUSER's Avatar
Sweet project, have you thought about using the 4x8 sheets of fiberglass material for covering walls, and bonding them to the plywood as the outer skin?
BRUSER is offline   Reply With Quote
Old September 17th, 2007, 06:53 PM   #11
redmud
10 0011 10101
redmud's Avatar
Man, you weren't kidding Jeepr, that's a helluva project! Looks good. When can I expect delivery? :tonka:
redmud is offline   Reply With Quote
Old September 17th, 2007, 06:54 PM   #12
sodapop
Support the Sport!
sodapop's Avatar
Cool post, I'd like to watch you finish it. keep posting pics and stuff! make sure you keep a tally of your build sheet too!
Old September 17th, 2007, 07:54 PM   #13
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
I'd be interested in following along.
@clarkstoncracker
Old September 17th, 2007, 08:12 PM   #14
JEEPR
Playing Possum
JEEPR's Avatar
Yes, what do they call that stuff? Filon or something? I may do it some time down the road. Right now I am trying to keep the budget down.
Here are a couple of updated pics, the interior roof is in and the galley is started. I would have a bunch more done, but I took 4 days off for the Pig Gig..
Next is framing in the galley and running electrical.
Redmud, what would you do with it, it already has a functioning axle?!?!
Would you trade me Tommy for it? :tonka:
Old September 17th, 2007, 08:27 PM   #15
redmud
10 0011 10101
redmud's Avatar
I fixed the axle I believe there's even pictures of me wheelin it this weekend (in 4 wheel drive). And yes, I talked to my sis, and we both agreed the teardrop trailer would be more fun than Tommy. So I'll get him packaged up. :tonka: Really though, that trailer looks fantastic.
Old September 17th, 2007, 09:15 PM   #16
JEEPR
Playing Possum
JEEPR's Avatar
Thanks, it's actually been a lot of fun to build. I am really building it by the seat of my pants. My plans don't consist of any measurements. So a I am just looking at things and seeing if I like how they come out. I tell you what, it's square. I cut the ply for the inside and it can't be more that 1/32nd of an inch off.
You like my 30 year old Craftsman electric tool set? Sorry the circular saw isn't in there.
Do all of Tommy's Jeeps come in the package deal?
Old September 17th, 2007, 09:24 PM   #17
Locascio
Stinky Turd
Locascio's Avatar
Lookin good!
Locascio is offline   Reply With Quote
Old September 17th, 2007, 09:34 PM   #18
KaiserJeep
boogidy boogidy boo
KaiserJeep's Avatar
That looks sweet!! Keep it up and keep the write up going!!
KaiserJeep is offline   Reply With Quote
Old September 17th, 2007, 09:57 PM   #19
dumperdave
dumperdave's Avatar
Thumbs up Neat-O Dude Rock On
Great project keep this updated I wanna see how it turns out.
dumperdave is offline   Reply With Quote
Old September 18th, 2007, 09:52 AM   #20
akozman
Chrome Trucker Chicks Rul
akozman's Avatar
that's good stuff there. looks like you even know what you're doing.
akozman is offline   Reply With Quote
Page generated in 0.75491 seconds with 83 queries
