ZJ disc brake setup with new/rebuilt calipers SOLD - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 17th, 2007, 04:55 AM   #1
redmud
10 0011 10101
redmud's Avatar
Smile ZJ disc brake setup with new/rebuilt calipers SOLD
This is pretty much everything from the backing plates out, Including a set of re manned calipers. All parking brake hardware also. You just need to supply discs and pads. $100.SOLD
redmud is offline
Old September 17th, 2007, 09:29 AM   #2
Dave Kerwin
web wheeling, hard.
Dave Kerwin's Avatar
this is for the zj dana35, correct?
does it come with the ZJ proportioning valve?
no rotors and pads, correct?
Dave Kerwin is offline
Old September 17th, 2007, 01:10 PM   #3
redmud
10 0011 10101
redmud's Avatar
It fits any 35/ jeep 44 (TJ/ZJ/XJ, etc...) No valve or pads or rotors. Backing plates out, pretty much everything else. Came off a 44a.
redmud is offline
Old September 17th, 2007, 01:12 PM   #4
shreddedbark
shreddedbark's Avatar
I'll give ya a pack of Camel Lights for it.
shreddedbark is offline
Old September 17th, 2007, 02:19 PM   #5
redmud
10 0011 10101
redmud's Avatar
stay outta my thread, pal!:tonka:
redmud is offline
Old September 17th, 2007, 03:41 PM   #6
bbaXJ
Yooper In Training
bbaXJ's Avatar
Very interested, put me in line.
bbaXJ is offline
Old September 17th, 2007, 05:38 PM   #7
redmud
10 0011 10101
redmud's Avatar
I'm not sure Mr. Kerwin is interested. If you want 'em shoot me a number I can contact you at. I'm home every night this week except Tuesday night.
redmud is offline
Old September 18th, 2007, 03:11 PM   #8
Wingnut
Ready 4 Hockey 2 start
Wingnut's Avatar
Could you post pics?
You could put disc's on the Tj w/ that!
I might be intersted. where did you find this?
Or just parts saved up?
just wondering.
Wingnut is offline
Old September 18th, 2007, 05:41 PM   #9
rodolo
Das BOOT!
rodolo's Avatar
They are the same set up I'm using and love it they bolted right up I chose to go a different route on the e-brake. Also you may need to run new brake lines on the axle if yours snap apart like mine.
They are the same as Tera-flex, they are getting them from ZJ's also.
Bump for a great set up Redmud
rodolo is offline
Old September 18th, 2007, 06:41 PM   #10
redmud
10 0011 10101
redmud's Avatar
just wondering.
I can post some pics, but it's just some backing plates and hardware. Shoot me a PM if you want, I'm out your way quite a bit.
redmud is offline
Old September 18th, 2007, 06:43 PM   #11
redmud
10 0011 10101
redmud's Avatar
thanks, bud!
However: your lines snapped because you put out like a million Lb/Ft of torque every time you turn a wrench. Us mortals don't have problems like that!!!
redmud is offline
Old September 20th, 2007, 08:12 PM   #12
redmud
10 0011 10101
redmud's Avatar
Bump! I'll go 100 if you pick them up this weekend.
redmud is offline
Old September 22nd, 2007, 10:03 AM   #13
redmud
10 0011 10101
redmud's Avatar
Btt
redmud is offline
Old September 22nd, 2007, 10:12 AM   #14
SlayerXJ
To Live is To Die
SlayerXJ's Avatar
So you have the caliper mounting brackets/backing plates and calipers...All the bolts too? WHat about the soft lines on the calipers? still there?
Pending your answers, i'd cough up 100 if you met me 1/2 way.
SlayerXJ is offline
Old September 22nd, 2007, 10:12 AM   #15
Blackjackbender
are the rear brakes vented or solid rotors? ive never seen the ZJ brake setup only other conversion/junkyard swaps.
Blackjackbender is offline
Old September 22nd, 2007, 03:34 PM   #16
redmud
10 0011 10101
redmud's Avatar
You have a PM. I posted pics. It all seems to be there. I could meet you in Brighton, that's halfway.
I have a set of stock rotors that are rusted to the spare axles I bought from Shawn, and they are solid discs. I'm sure that there is a aftermarket slotted or vented one available. I won't sell the ones that I have as I have not had a chance to Mic them, but they had a pretty rough ride in the back of the jeep, and aren't exactly round anymore. I just use 'em to protect the lugs and flange on the shafts.
redmud is offline
Old September 22nd, 2007, 03:35 PM   #17
redmud
10 0011 10101
redmud's Avatar
on the soft lines, you will have to disconnect your wheel cylinders and re-connect the lines where the cut lines are on the Caliper lines.
redmud is offline
Old September 22nd, 2007, 03:45 PM   #18
Blackjackbender
alright. i wasn't sure if the GC used solid or vented
Old September 22nd, 2007, 08:59 PM   #19
redmud
10 0011 10101
redmud's Avatar
Sale pending to SlayerXJ
(sorry I had to hang up on ya so fast, Slayer, I got my grill fire out out with minimal armhair loss, tho!)
redmud is offline
Old September 23rd, 2007, 01:46 PM   #20
redmud
10 0011 10101
redmud's Avatar
Sold to Slayer XJ - good to meet ya!
redmud is offline
Page generated in 0.45965 seconds with 83 queries
