Axle Info - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 16th, 2007, 03:32 AM   #1
NewGuyYJ
NewGuyYJ's Avatar
Default Axle Info
Just want to contribute to the axle forum. This is taken from the jeepforum.com YJ forum. All credit goes to the original author.
Originally Posted by Ares
I've been seeing a lot of questions regarding axle strength, U-joints, tire size, etc etc. I found that theres a lot of info out there, but it can be hard to put it all together and sometimes hard to find. So, I've taken a little reasearch, a nice artical provided by JP Magazine and a few websites to help out a bit. Here is some axle information: (Note, most Dana axle spec information is given for Jeep application axles, spec information for other manufacturers may vary [i.e. Chevy axle width, stock gearing, etc])
FRONT AXLES
D27 Front Axle:
Full Floating
Vehicles: '66-'71 CJ-5 and CJ-6; '63-'70 Wagoneer; '67-'71 C-101 Jeepster
Ring Gear: 7.2"
Stock Gearing:
Axleshaft Spline: 10
Axleshaft Diameter: 1.13"
Axle Joint: Spicer 260X
Knuckle: Closed
Brakes: Drum 10" 11"
Weakness: Weak axle for upgrades, low spline count, weak carrier
Width: 51" (CJ and Jeepster), 57.5" (Wagoneer)
Wheel Bolt: 5x5.5"
Max Recommended Tire Size: 31"
D30 Front Axle:
Full/Semi Floating
Vehicles: From ’72 CJ-5, CJ-6, CJ-7, CJ-8, YJ, TJ, XJ, ZJ, C104, WJ
Ring Gear: 7.125”, 7.33” (TJ/WJ Only)
Stock Gearing: 3.07, 3.54 (3.55), 3.73, 4.10 (4.11)
Axleshaft Spline: 27
Axleshaft Diameter: 1.16”, 1.193” (TJ/WJ Only)
Axle Joint: Spicer 260X (pre ’95.5), Spicer 297/760X (post ’95.5), CV & 760 U-Joint (TJ/WJ)
Knuckle: Open
Brakes: Drum 11” (pre ’76), Disc (post ’76)
Weakness: 260X U-joint; YJ Vacuum motor fails; standard CV problems
Width: 51” (’72-’75 CJ, C-104), 53” (’76-’81 CJ), 56” (’82-’86 CJ), 60.5” (TJ, YJ, XJ, WJ)
Wheel Bolt: 5x5.5” (CJ/C-104), 5x4.5” (others)
Max Recommended Tire Size: 35”
AAM 790 Front Axle
Semi Floating
Vehicles: '05 and later WK
Ring Gear: 7.87"
Stock Gearing:
Axleshaft Spline:
Axleshaft Diameter:
Axleshaft Joint: CV
Knuckle: Open
Brakes: Disc
Weakness: Limited modification ability, small ring gear
Width:
Wheel Bolt:
Max Recommended Tire Size: 32"
D44 Front Axle:
Full/Semi Floating
Vehicles: ’57-’65 FC-170; ’63-’70 Gladiator; '67-'79 1/2 & 3/4 Ton Ford Pickups; ’71-’87 J-Series; ’71-’91 Wagoneer; '72-'93 1/2 & 3/4 Ton Dodge Pickups; '73-'79 1/2 & 3/4 Ton Chevy Pickups; ’74-’83 Cherokee; ’03-’06 Rubicon
Ring Gear: 8.5”
Stock Gearing: Many
Axleshaft Spline: 19 (pre ’71), 30 (post ’71)
Axleshaft Diameter: 1.25” (19 spline), 1.31” (30 spline)
Axle Joint: Spicer 206X (pre ’73), Spicer 297/760C (post ’73)
Knuckle: Closed (pre ’73), Open (post ’73)
Brakes: Drum 11” (pre ’73), Disc (post ’73)
Weakness: 260X and 19 spline axleshafts
Width: 63” (FC-170), 57.5” (’71-’73 Wagoneer), 59” (’74 and later Wagoneer), 65.5” (J-Series), 60.5” (Rubicon), Full Width (Ford, Dodge, Chevy)
Wheel Bolt: (Varies)
Max Recommended Tire Size: 37”
D60 Front Axle:
Full Floating
Vehicles: ‘67-’69 Kaiser M-715; ‘72-‘93 3/4 & 1 Ton Dodge Pickups; ‘74-‘77 3/4 Ton Ford Pickups; ‘77-‘87 3/4 & 1 Ton Chevy Pickups; ‘78-‘79 1 Ton Ford Pickups
Ring Gear: 9.75”
Stock Gearing: 4.10, 4.56
Axleshaft Spline: 30
Axleshaft Diameter: 1.31”
Axle Joint: Unknown Spicer
Knuckle: Closed
Brakes: Drum 13”
Weakness: Metallurgically axleshafts inferior to modern metals
Width: 72.5” (M-715), Full Width (Ford, Dodge and Chevy)
Wheel Bolt: 6x8.25”
Max Recommended Tire Size: 42”
REAR AXLES
D35 Rear Axle:
Semi-floating (’85-’89), C-clip (’90 and later)
Vehicles: Most XJ; YJ; TJ (except Rubicon); ZJ; some WJ
Ring Gear: 7.562”
Axleshaft Diameter: 1.13”
Brakes: Drum 11”; Disc (later ZJ/WJ)
Weakness: Weak carrier & axleshafts
Width: 60.5”
Wheel Bolt: 5x4.5”
Max Recommended Tire Size: 33”
D44 Rear Axle:
Semi Floating
Vehicles (here we go…*long breath*): ’49-’65 6cyl Willy Wagons; ’49.5-’53 CJ-3A; ’53-’68 CJ-3B; ’50-’52 M-38; ’52-’57 M-38A1; ’53-’57 M-170; ’55-’75 CJ-5 & CJ-6; ’85.5-’86 CJ-7; ’58-’65 FC-150; ’57-’65 FC-170; ’63-’70 Wagoneer & Gladiator Pickup; ’67-’71 C-101 Jeepster; ’72-’73 C-104; ’71-’75 Wagoneer & ½-ton J-Series; ’74-’83 Cherokee; ’87-’91 Grand Wagoneer; Some ’86-’92 XJ and MJ; Some ’97-’06 TJ; ’99-’04 WJ; ’96-’98 ZJ
Ring Gear: 8.5”, 8.9” (WJ only )
Stock Gearing: Many, including 3.55, 3.73, 4.11
Axleshaft Spline: 10 (’49-’55), 19 (’56-’70.5), 30 (’70.5 and later)
Axleshaft Diameter: 1.193” (WJ/ZJ) 1.25” (10 and 19 Spline), 1.31 (30 Spline)
Brakes: Drum 9”, 10”, 11”; Disc (Rubicon, ZJ, WJ)
Weakness: 10 & 19 Spline, Some aluminum housings.
Width: 50.5” (up to ’75 CJ, FC, C-101, C-104), 54.5” (’85-’86 CJ), 57.5” (’63-’73 Wagoneer), 60.5” (XJ, MJ, TJ, ZJ, WJ), 65.5” (FSJ Cherokee, J-Series)
Wheel Bolt: Varies
D53 Rear Axle:
Semi Floating
Vehicles: '55-'65 Willys pickup; '63-'69 Gladiator; '57-'65 FC-170
Ring Gear: 9.25"
Stock Gearing:
Axleshaft Spline: 20
Axleshaft Diameter: 1.31"
Brakes: Drum 11"
Weakness: Hard to find parts, low spline
Width: 65.5" (Gladitaor), 63" (Others)
Wheel Bolt: 5x5.5"
Max Recommended Tire Size: 35"
D60 Rear Axle:
Semi/Full Floating
Vehicles: ‘67-‘69 1/2 & 3/4 Ton Ford Pickups; ’69-’87 J-2000/J-20; ‘72-‘93 3/4 Ton Dodge Pickups
Ring Gear: 9.75”
Stock Gearing 4.10, 4.56
Brakes: Drum 12”
Weakness:
Width: 65.5” (J-2000/J-20), Full Width (Ford, Dodge & Chevy)
Wheel Bolt: 8x6.5”
D70 Rear Axle:
Full Floating
Vehicles:’58-’68 FC-170 w/dual rear wheels; ’63-’68 J-3000 w/dual rear wheels; ’67-’69 M-715; CJ-10; '72-‘93 3/4 & 1 Ton Dodge Pickups; ‘76-‘77 3/4 Ton Ford Pickups; ‘77-‘87 1 Ton Chevrolet Pickups; ‘78-‘79 1 Ton Ford Pickups
Ring Gear: 10.5”
Axleshaft Spline: 23, 35
Axleshaft Diameter: 1.5”
Brakes: Drum 13”
Weakness: Poor parts availability
Width: 59” (FC & Pickup), 72” (M-715), Full Width (Ford, Dodge and Chevy)
Wheel Bolt: 6x7.25” (M-715), 8x6.5” (others)
Max Recommended Tire Size: 44”
AMC20 Rear Axle:
Semi Floating
Vehicles: ’76-’86 CJ; ’76-’91 Wagoneer and J-10
Ring Gear: 8.875”
Stock Gearing: 2.76, 3.07
Brakes: Drum 11”
Weakness: 2 piece axleshafts (CJ only), tubes spin, 20 spline
Width: 50.5” (’76-’81 CJ), 54.5” (’82-’86 CJ), 59” (Wagoneer), 65.5” (J-Series)
Wheel Bolt: 5x5.5” (CJ), 6x5.5” (Wagoneer and J-Series)
Max Recommended Tire Size: 33”-35”
Chrysler 8.25 Rear Axle:
C-clip
Vehicles: '91-'01 XJ
Ring Gear: 8.25”
Stock Gearing: 3.55, 3.73, 4.10
Axleshaft Spline: 27 ('91-'96), 29 ('96-'01)
Axleshaft Diameter: 1.17” (27 spline), 1.21 (29 spline)
Brakes: Drum 11”
Weakness: 27 spline, c-clip
Width: 60.5”
Wheel Bolt: 5x4.5”
Ford 8.8 Rear Axle
C-clip
Vehicles: Ford Explorer (Prefered Swap, information reflects Explorer only), Ford F-Series , Ford Ranger
Ring Gear: 8.8"
Stock Gearing: 3.08, 3.27, 3.55, 3.73, 4.10
Axleshaft Spline: 28, 31
Axleshaft Diameter: 1.320"
Brakes: Drum ('91-'94), Disc ('95-'01)
Weakness: C-clip, weak carrier
Width: 59.625" to 65.6"
Wheel Bolt: Most 5x4.5"
Max Recommended Tire Size: 40"
AXLE STRENGHTS:
COT - Continuous Output Torque
MOT - Maximum Output Torque
Dana 35 ........................ COT: 870 MOT: 3480
AMC 20 .........................
Chrysler 8.25 .................
Dana 53 ........................
Dana 44 ........................ COT: 1100 MOT: 4460
Ford 8.8 28 spline ........... COT: 1250 MOT: 4600
Ford 8.8 31 spline ........... COT: 1360 MOT: 5100
Dana 60 semifloat ........... COT: 1500 MOT: 5500
Dana 70 ........................
Rockwell 2.5 Ton ............ Industructable
IDENTIFICATION:
Tag Identification:
D30: “30” cast into back of diff casing on top right and left next to diff cover. Tag bolted on diff cover with axle ID and gear ratio.
D35: “35” cast into back of diff casing on top right and left next to diff cover. “C” next to “35” DOES NOT stand for c-clip, but “custom” (unfinished by Spicer). Tag bolted on diff cover with axle ID and gear ratio.
D44: In most cases “44” into back of diff casing on top right and left next to diff cover. Tag bolted on diff cover with axle ID and gear ratio.
D60: Similar looking casing to the D44, except the oil fill plug is elevated to provide more fluid for the larger gears.
Chrysler 8.25: Tag wrapped around passenger side tube with axle ID and gear ratio.
Ford 8.8: See Joe Dillard and T.Dome's writeup linked at the bottom of the page
Differential Cover Identification:
AMC 20: 12 cover bolts, round cover, fill plug not present
D27: 10 cover bolts, oval with straight sides, distinguished ring gear extension, low fill plug
D30: 10 cover bolts (five on top, five on bottom), oval cover w/flat sides, fill plug just below centerline
D35: 10 cover bolts, evenly spaced, oval "dome" shaped cover with low fill plug
D44: 10 cover bolts, hexagon shaped cover with very round edges, fill plug on centerline
D60: 10 cover bolts, hexagon shaped cover, fill plug on centerline
D70: 10 cover bolts, hexagon shaped cover, fill plug on centerline
Chrystler 8.25: 10 cover bolts, oval shaped cover, fill plug just below centerline
Ford 8.8: 10 cover bolts, square with very round edges, fill plug not present on cover
Gear Identification:
If the gears are unidentifiable from the tag or if the tag is missing, there are two methods to find the gear ratio.
1) Spin the tire one full rotation and watch how far the driveshaft rotates. Double the amount the driveshaft rotated, this gives you your gear ratio. Be sure you are spinning the tire forwards.
2) Count ring & pinion gears: Count the number of teeth on the ring and the pinion. Then divide the ring teeth by the pinion teeth to attain the gear ratio.
USEFUL LINKS
Identification information along with applications outside the Jeep family can be found here
Very informational thread by OhioYJ covering the Jeep, GM, Ford and Chrystler axles at cdmfabrication
All the information you could ever need pertaining to the Ford 8.8 by Joe Dillard and T.Dome
More information better encompasing years and qualities of the D60 and Ford 9"
A writeup by Tomb Raider on axle u-joint replacement
Another writeup by OhioYJ also on u-joint replacement
Edit: links didn't work, fixed I hope
NewGuyYJ is offline   Reply With Quote
Old September 16th, 2007, 09:19 AM   #2
PavementPounder
PavementPounder's Avatar
Wow. There's a bunch of wrong crap in there. That says that all D60 fronts were closed knuckle and only 30-spline.
Old September 16th, 2007, 09:52 AM   #3
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
Agreed.
Old September 16th, 2007, 01:43 PM   #4
gofastbobby
The guy Dale doesn't know
gofastbobby's Avatar
congrats on your first rb post.
gofastbobby is offline   Reply With Quote
Old September 16th, 2007, 05:12 PM   #5
NewGuyYJ
NewGuyYJ's Avatar
I thought it was useful, and maybe instead of just deeming it complete crap, it can be polished to be more accurate. Just trying to help...
Old September 16th, 2007, 08:19 PM   #6
PavementPounder
True. Do that and then post it again as your own.
Old September 16th, 2007, 09:33 PM   #7
clarkstoncracker
lol
clarkstoncracker's Avatar
x2.
Someone quote/edit what you deem as wrong, and I'll fix the post.
Thanks for the axle info post.
Old September 16th, 2007, 10:19 PM   #8
95geo
newbie
95geo's Avatar
this has already been polished by the most critical and knowledgeable people in the world, no sense in reinventing the wheel
http://www.pirate4x4.com/tech/
http://www.pirate4x4.com/tech/billav...ont/index.html
Old September 16th, 2007, 10:36 PM   #9
NewGuyYJ
NewGuyYJ's Avatar
But there is sense in consolidating all of the wealth found in pirate4x4 into an easy-to-read summary, since we all know that lazy people outnumber motivated people. And what do lazy people do? Repost the same questions over and over, without searching, so I figured might as well try to cut down on the axle comparison posts that always pop up from the lazy people :tonka:
Anyways, I'll try to polish it up some as well, just give me time
Old September 17th, 2007, 07:05 AM   #10
95geo
newbie
95geo's Avatar
I would find a more accurate list to start with.....
dana 44 front, 19 spline, good to 37s
dana 44 rear, 30 spline, good to 35s
rockwell, "industructable"
dana 60 front, bolt pattern 6x8.25" 13" drum brakes
how many things are wrong with this? for a dana 60....
Knuckle: Closed
Brakes: Drum 13
Width: 72.5 (M-715), Full Width (Ford, Dodge and Chevy)
Wheel Bolt: 6x8.25
Old September 18th, 2007, 05:46 PM   #11
Cooter
Cooter's Avatar
The gear ratio calculation is far too over simplified, to the point of being incorrect.
Old September 29th, 2007, 10:16 AM   #12
joe_jeep
welfare wheeler
joe_jeep's Avatar
40's on a stock 8.8?
Page generated in 0.40631 seconds with 59 queries
