ZJ 5.5 short arm lift. what springs should i use? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 13th, 2007, 05:11 PM   #1
steveo
In the band!
Default ZJ 5.5 short arm lift. what springs should i use?
I am getting ready to do a 5.5" short arm lift on my zj. I will be using the stock uppers, fabbing adjustable lowers and a wheel to wheel tie rod to replace the factory setup. i am dropping the t-case and adding a steering stabilizer in the front making new trackbars and extending my brakelines.. this setup will be running 33" tires. My question is since this will stay my DD i want springs and shocks that ride good on the highway. I am thinking that i will avoid rusty's since they are so soft.
Old September 13th, 2007, 06:05 PM   #2
Chiefwoohaw
Pokerob is my B*tch!
Chiefwoohaw's Avatar
First: You don't need to drop the Tcase. The Jeep is long enough that you won't have any issues. In my old Jeep I used BDS springs because I think the front was like $150 and then did a F>R swap with spacers in the back to make up the difference.
Old September 13th, 2007, 06:09 PM   #3
steveo
In the band!
yeah, i dont want spacers, if i did i would just block the 3 inch springs i already have. i am going with 5.5 inch springs front and rear. if its worth the time and effort, its worth doing it right.
Old September 13th, 2007, 07:19 PM   #4
Chiefwoohaw
5.5 rear springs from BDS were I think $150 as well.
O and nothing at that height and short arms, adjustable or not, is going to ride well. You will now be using your bushings as shocks.
Old September 13th, 2007, 07:22 PM   #5
steveo
In the band!
i know, but i dont have the time to have my jeep torn apart to do long arms right now. I am going to build longarms in december when i am on break for 3 weeks.
Old September 13th, 2007, 09:41 PM   #6
rockrat
rockrat's Avatar
if you're doing the long arm in December, do your lift then 1x=cheaper.
Mine had 6.5" on short arms and rode worse than my J20 ( tank)
rockrat is offline   Reply With Quote
Old September 13th, 2007, 09:43 PM   #7
rockrat
rockrat's Avatar
my Rusty's springs are comfy on the road and just right off, as for shocks, I'm using Procomp es9000 extendeds(35")
Old September 13th, 2007, 10:06 PM   #8
steveo
In the band!
i have my own shop, and can make all of my parts. basically the only cost i will have is for items that i cannot produce myself. the lower arms i am making this month will be used when making my long arms, or i can sell them. i will not go over 5.5 inches, as there is no need. for now i am just going to do control arms and leave it untrimmed with 31's for deer season muddyness even with 31's i need the adjustable arms, since the axles need to be re centered. mostly i wanted an idea what springs and shocks would be ideal so that i could start looking for someone who will get them for me at cost.
Page generated in 0.21478 seconds with 47 queries
