Warn Hub Conversion For Dana 30's - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 13th, 2007, 09:16 AM   #1
Stone
Ultimate Mall Wheeler
Stone's Avatar
Send a message via AIM to Stone
Default Warn Hub Conversion For Dana 30's
The Warn hub kits for the YJ and TJ Dana 30's sell for $1,000+. I'm interested in free-wheeling hubs but I guess it just leaves me wondering why someone would put that much money into a Dana 30 when a 44 can be had for much less? Is there something I'm missing?
TIA
Stone is offline   Reply With Quote
Old September 13th, 2007, 09:20 AM   #2
No, you aren't missing anything. Its expensive and mostly unnecessary.
Old September 13th, 2007, 01:53 PM   #3
mean_greenEXJAY
YJ now
mean_greenEXJAY's Avatar
I was really thinking about it when i needed to put new unit bearings in my front axle, because the new bearing are $200+each, but i ended up just getting cheapper bearing asseblies. There are some advantages to having lockouts and a tappered bearing set up, but not worth the price.
Old September 17th, 2007, 06:43 PM   #4
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
TIA
Few reasons...
You can't get a 44 with lockouts and keep the same bolt pattern. Then you also run into the fab work needed to install said d44...it's not a bolt in like the hub conversion is.
Unit bearings are of course expensive, but then the lockouts are not exactly super strong.
Lots of people can put a lunchbox locker in. Lots can do the hub conversion but not all of these can do, or want to do, the fab needed for a 44 install.
Old September 17th, 2007, 07:03 PM   #5
Blackjackbender
I run the kit. (on a rubi type housing but HP)
I would swap a real front 44 in though if I had to do it again.
Page generated in 0.17225 seconds with 38 queries
