Rubicon D44 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 12th, 2007, 02:02 PM   #1
Chiefwoohaw
Pokerob is my B*tch!
Chiefwoohaw's Avatar
Default Rubicon D44
Are the gears in a Rubi 44 the same as in a say FSJ 44?
I'm looking to pick up some 4:88s I believe.
Thanks in Advance
Edit: o yeah, I'm searching now as well just thought I'd put this up for the next guy and for myself if I can't find the answer
Old September 12th, 2007, 02:20 PM   #2
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Thanks in Advance
Rubi 44 never came with 4.88 only 4.10. 4.88 are availabe, but all the "Rubi" gear sets are the "thick" gears, which can be used in the FSJ 44 (non HP) but you'll have to use the 3.73 and down carrier (and probably drill out the carrier bolt holes).
Old September 12th, 2007, 02:58 PM   #3
Chiefwoohaw
I"m looking at it the other way around. I want to put 4:88s in my Rubi Axles.
Old September 12th, 2007, 03:08 PM   #4
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
He's saying you'll need to use "thick" 4.88 gears. 4.88s from a Waggy 44 (which would be aftermarket) wouldn't work in your Rubicon 44.
Craig
Old September 12th, 2007, 03:25 PM   #5
Chiefwoohaw
that's what I got as well. There is a guy close by with 4.56s out of a FSJ d44 but I see that they won't work.
I wanted 4.88s anyhow but cheap is cheap so good thing they won't fit.
Page generated in 0.19303 seconds with 38 queries
