Scout stub shaft - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 12th, 2007, 12:30 PM   #1
TJontherox
Mall Rated
TJontherox's Avatar
Send a message via Yahoo to TJontherox
Default Scout stub shaft
Tried searching real quick here at lunch but couldn't find anything. Is there a d44 stub shaft out of another vehicle that would fit a scout axle to broaden my search for a new stub shaft until I can one day afford chromo's.
TJontherox is offline   Reply With Quote
Old September 12th, 2007, 01:20 PM   #2
95geo
newbie
95geo's Avatar
I think scout is specific to scout. yukons are about $100 each and they dont open up in the ears as easily as the stockers. superiors are ideal but thats about 2x the price.... both are guaranteed
Old September 12th, 2007, 03:45 PM   #3
TJontherox
Mall Rated
TJontherox's Avatar
I'll eventually step up to stronger shafts and ctm's but at the moment its not in the budget. I was just curious if someone has done some swapping before and found something else that may work. I need to track down 1 stub currently to have both sides with a joint ready to swap in when they break.
Old September 12th, 2007, 06:33 PM   #4
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
If you need just a replacement I believe a CJ5 outer for a D30 is the same.
Old September 12th, 2007, 06:50 PM   #5
TJontherox
Mall Rated
TJontherox's Avatar
I was kind of looking for something like that earlier just ran out of time at lunch. I'll look into it a little more but I thought I had heard that once before, just wondering if anyone has actually done the swap.
Old September 12th, 2007, 07:06 PM   #6
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
cj 30 is the same length just smaller joint (260x)
that is the only other similar stub
Old September 13th, 2007, 10:53 AM   #7
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
X2
8.72" CJ/Scout stub.
Yukon offers one but only in a 297 (760x) series joint so you'll also need the inner.
Old September 13th, 2007, 11:37 AM   #8
Jeepaholic
Jeepaholic's Avatar
I thought the scouts are 297?
Old September 13th, 2007, 01:30 PM   #9
Jeeperz Creeperz
GL 4x4 Vendors
Last I did was a 260.
Old September 13th, 2007, 03:09 PM   #10
95geo
newbie
95geo's Avatar
quit messing around with normal axles, everyone knows your not cool unless you have portals or rockwells
Old September 13th, 2007, 03:25 PM   #11
TJontherox
Mall Rated
TJontherox's Avatar
Originally Posted by 95geo View Post
quit messing around with normal axles, everyone knows your not cool unless you have 60's
Fixed
Old September 13th, 2007, 06:54 PM   #12
fullthrottle
2013 King of da Moustache
fullthrottle's Avatar
Send a message via AIM to fullthrottle
quit messing around with normal axles, everyone knows your not cool unless you have a welded d30!
Fixed
refixed!
fullthrottle is offline   Reply With Quote
Old September 13th, 2007, 09:55 PM   #13
BIGBEN
All out Idiot
BIGBEN's Avatar
one ton time.
Originally Posted by Stan View Post
My hope is that one day all women will realize just how well they could have it if they just shut their big fucking whining mouths.
BIGBEN is offline   Reply With Quote
Old September 14th, 2007, 07:19 AM   #14
95geo
newbie
95geo's Avatar
In all honesty though, if you plan on making the jeep any bigger I would look into a 60 for the front. by the time you put chromoly shafts in the 44 the only price difference between the two is really the initial cost of the axle. this is if you build it conservatively, everyone knows you can spend 6k building a junk yard 60. johnnyj is still running 30 spline outers.
save the money that you would spend on chromoly shafts for the 44, regear and lock a 60 and run it.
some peole think they need a 60, others think they can get away witout one... the way you built your jeep i think chromoly 44s would be a waste of money.
Old September 15th, 2007, 09:03 AM   #15
TJontherox
Mall Rated
TJontherox's Avatar
I may just have to wait to see what my driving style is like. This is my first "real" off road rig and I haven't quite developed a style yet. The Unlimited open house was the first trial of it and obviously I can't get a driving style in a few hours time. I may end up driving like Crystal. Her 44 has held up to some pretty good abuse so far without breakage. I'm sure you've seen her on the rev limiter on her CJ a time or 2. The u joint breakage could have been a fluke thing, I did after all buy the axles from Mike, so that u joint may have stressed before the axle was put in the Jeep. I'll have to weigh my options, I have plenty of time since I can't afford chromos or 60's yet. :tonka:
Page generated in 0.31514 seconds with 68 queries
