D30 Shafts - TJ / XJ - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 8th, 2007, 09:35 PM   #1
DuffMan
Your Message Here
DuffMan's Avatar
Default D30 Shafts - TJ / XJ
Will XJ D30 High Pinion shafts work in a TJ with a low pinion D30?
I was looking at picking up a pair of spares from an XJ but want to be sure they'd fit first.
Old September 8th, 2007, 10:32 PM   #2
scorpio_vette
scorpio_vette's Avatar
Send a message via MSN to scorpio_vette Send a message via Yahoo to scorpio_vette
yes.
and by the way. low pinion D30 TJ shafts will also work in a XJ high pinion D30
PS: just don't grab the XJ vacuum disconnect passenger axle shaft. that won't work. but all XJ driver, and the XJ non-disconnect passenger shafts will work. if that sounds confusing, don't worry about it. once you have the shafts in your hand, you'll understand without anybody explaining it.
scorpio_vette is offline   Reply With Quote
Old September 8th, 2007, 10:38 PM   #3
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
Make sure you get the late model ones with the 297x u-joints. There are early, non disconnect versions with smaller 260 joints in them.
Also, non-cv style ZJ shafts will work as well, and they all have the bugger u-joints.
Old September 9th, 2007, 10:35 AM   #4
scorpio_vette
oh yeah minor detail. thanks for covering that.
and personally i would stay away from ZJ shafts with "bugger" u-joints (they tend to be a little runny and get stuck under chairs. LOL). but i've heard that the ZJ shafts with the bigger u-joints will work too.
Old September 9th, 2007, 10:50 AM   #5
shreddedbark
shreddedbark's Avatar
Originally Posted by scorpio_vette View Post
...once you have the shafts in your hand, you'll understand ...
shreddedbark is offline   Reply With Quote
Old September 9th, 2007, 01:39 PM   #6
Cooter
Cooter's Avatar
Umm, Yeah.
You're welcome, oh great tech mod of GL4x4. I'm pretty sure buying early D30 shafts with the 260 u-joints wouldn't be considered a "minor detail" for anyone running 33s or larger.
Old September 9th, 2007, 06:26 PM   #7
DuffMan
Your Message Here
DuffMan's Avatar
These have brand new 760 u-joints in them.
I'm running 33s, and considering moving to 35s. Deal breaker?
Old September 9th, 2007, 06:34 PM   #8
Ebs
760s are the good u-joints, run 'em.
Old September 11th, 2007, 01:38 PM   #9
scorpio_vette
Umm, Yeah.
DUDE???.........that kick in the junk hurts. even if it's just a smiley. LOL
guess i should explain myself. LOL around people that know me, when i screw up, i jokingly say........"minor detail" instead of "your right". LOL
so.....your right...thank you for cover the 260u-joint part that i overlooked.
and here's back to ya...
Page generated in 0.22865 seconds with 50 queries
