Hey ford electric relay guys.. this bugs me.. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 1st, 2006, 10:13 PM   #1
clarkstoncracker
lol
clarkstoncracker's Avatar
Default Hey ford electric relay guys.. this bugs me..
What triggers the locks to lock in the 05 f-350's?
Giving that the truck only moves 3 times a week, so I haven't pinned it down.. Is it a timer after you put it in drive, or is it a steering relay?
Usually it happens 10-12 seconds... But today, it didn't lock until about 30 seconds when I turned a corner.
This bothers me..
I'm talking about the auto lock thing.
Old March 2nd, 2006, 01:03 PM   #2
Usually its speed based.
Usually its also configurable.
Usually....
Old March 2nd, 2006, 01:08 PM   #3
Arnie897
y=mx+b
Arnie897's Avatar
Send a message via AIM to Arnie897
I think it goes through the computer somehow using the speed sensor, tranny range sensor and probably the brake pedal somehow. I have procedures to disable it on Ford Explorer's if you are interested.
Arnie897 is offline   Reply With Quote
Old March 2nd, 2006, 01:51 PM   #4
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
Its controled by the body controler. its based on speed like 7-10 mph and then the locks trigger. they can be shut off with the procedure Arnie mensioned.
Yetti
Old March 2nd, 2006, 02:05 PM   #5
Lothos
KD8GKB
Lothos's Avatar
Speed in excess of 5mph will trigger dome lights off, locks to lock, and seatbelt chime to ring if drivers belt not detected. Now, mind you the speed sensor is in the transmission, the cold can make it slower in responding. The check condition is 5mph though and there's a delay to detect the change.
Also, there's nanotech circuits that detect sudden accelleration/decelleration that will trigger the same PCM logic.
Old March 2nd, 2006, 04:16 PM   #6
clarkstoncracker
lol
Is this something easy, or is it computer controlled?
I would be very interested in it..
Old March 2nd, 2006, 06:05 PM   #7
Arnie897
y=mx+b
Arnie897's Avatar
I'm assuming that all Fords can use this....but I could be wrong.
The factory procedure to disable autolock can be accomplished in two ways:
Autolock Enable/Disable - Using the Keypad
To enable/disable autolock using the keyless entry keypad:
1. Enter five-digit permanent entry code into the keyless entry keypad.
2. Within 5 seconds of entering the code, press and hold the 7/8 button on the keypad.
3. Within 5 seconds of Step 2, and while holding the 7/8 button, press the 3/4 button on the keypad and release it.
4. Within 5 seconds of Step 3, release the 7/8 button on the keypad.
If the Autolock feature is disabled the horn will chirp once, if it is enabled the horn chirps once and then a second time once the sequence above is completed.
Autolock Enable/Disable through Igntion Switch
1. Close all doors.
2. Confirm the key is OFF.
3. Turn key from OFF to RUN.
4. Note Steps 4 through 7 must be carried out within 30 seconds.
Press Door lock control switch UNLOCK 3 times.
5. Turn the key from ON to OFF.
6. Press the door lock control switch UNLOCK 3 times.
7. Turn the key from OFF to ON.
8 Verify the horn chirps. This indicates the disable/enable mode has been entered and is ready for program changes.
9. Press door lock control switch UNLOCK button one more time, then press the LOCK button.
10. Verify the horn chirps one time, indicating that the autolock/relock feature is disabled. If one chirp is heard, followed by a longer sound of the horn the autolockk/relock feature is enabled. (Return to Step 9).
11. Turn the key to OFF position to exit enable/disable mode. If the Autolock status is changed, the horn will chirp once. If the status is not changed, no chirp will be heard. Return to Step 1.
Hope this helps....
Old March 4th, 2006, 08:57 AM   #8
clarkstoncracker
lol
Arnie, you rock!
Old March 4th, 2006, 09:22 AM   #9
Arnie897
y=mx+b
Arnie897's Avatar
no problem
Page generated in 0.26136 seconds with 50 queries
