d35 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 7th, 2007, 07:16 AM   #1
nvr-enuf-money
Old Hippie
nvr-enuf-money's Avatar
Default d35
Are all d35 non c-clip? If not, can I tell without dropping the cover? Are all d35's the same? Meaning you can change from c-clip to non c-clip with a parts swap? I got a d35 with 4;10's, when I opened it I found sand, mud, and rust. It has 2 in brakes{ my other 35 has 2.5 brakes}. I also got a 4;10 ring and pinion for the front, It looks great. How can I tell if its for a hp axel? I got extra axel shafts, brake drums with it. Should I keep it, or return it. It was very good price and I did not have to travel far. Thanks
nvr-enuf-money is offline   Reply With Quote
Old September 7th, 2007, 10:02 AM   #2
Some Dana 35s are C-clip, some aren't..thats all I can tell ya...
Old September 7th, 2007, 10:17 AM   #3
fullthrottle
2013 King of da Moustache
fullthrottle's Avatar
Send a message via AIM to fullthrottle
u must pull the d35 cover to tell a c-clip or not. as i know noother way to tell.
from factory jeep d35's came w/ open diffs, trac-loks and open diff w/ abs.
d-35's can be part swap to meet your needs. u can even put 30spline axle shafts and convert to disk. notworth allthat imo
on the front 4.10 r&p look for make or part # to identify it. ( spicer...ect)
gl w/ that.
i didnt know there was a difference on brake sizes for the d35. i wonder if one size is for c-clip and none c-clip.??
fullthrottle is offline   Reply With Quote
Old September 7th, 2007, 10:47 AM   #4
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
I know that 87-89 are non-c clip. i have heard that the non-c goes on to 92 but I can not verify that.
Old September 7th, 2007, 11:25 AM   #5
busyfixin
Balls Deep
busyfixin's Avatar
my 91 commanche is a non c-clip
Old September 28th, 2007, 09:15 PM   #6
joe_jeep
welfare wheeler
joe_jeep's Avatar
if you pull the drum off the non c is a flanged axle. it will have 4 bolts holding the axle in the tube. should be an access hole in the axle flange to get at the bolts i would think. unless they expect you to get at the bolts from the side. either way there will be 4 bolts holding the shaft into the housing behind the axle flange. 93 and newer are c clip. 92 and older are flanged. if you had a flanged dana 35 with a super 35 kit(30 spline shafts and locker) and did a little truss work it would be a pretty strong, light weight alxle with great ground clearance. i have run a c clip super 35 for about 6 years with no issues, but the c clips scare me.
Old September 30th, 2007, 10:19 AM   #7
ajmorell
most are c-clipped but some are not. Like mentioned above 87-89 aren't and I also know that the WJ (99+ Grands) D35 are non-clipped.
Page generated in 0.22877 seconds with 44 queries
