Rm125 problems - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 6th, 2007, 12:16 PM   #1
booblinker
Sore and Tired 24/7
booblinker's Avatar
Default Rm125 problems
i have an 84 RM125, It will start on the first kick, and runs decent when stopped. I fi rev it in nuetral it will rev pretty good, but as soon as it is under load, it bogs really bad, and won't go over 5 mph. Carb is clean, plug is new. I am running a br9es instead of a br9eg, but that shouldn't matter, at least i don't think it does. Could my reeds be the problem?
Old September 6th, 2007, 01:42 PM   #2
jeepguy74
jeepguy74's Avatar
clean the carb again sounds like you have a stuck something or othwer sounds like it running rich and fouling .....what does the plug look like (wet ..brown ..black??????
Old September 6th, 2007, 01:55 PM   #3
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
The "bog" under a load makes it sound too lean.
@clarkstoncracker
Old September 6th, 2007, 02:06 PM   #4
rustcharger
dubs ain't sh*t
rustcharger's Avatar
sounds like a worn top end to me.
rustcharger is offline   Reply With Quote
Old September 6th, 2007, 03:40 PM   #5
Motor Slut
I put the Ick in Dick.
Motor Slut's Avatar
Assuming this is the same bike you just put a Magneto/Stator in I have to ask if you checked the timing? Maybe it's not adjustable but if it is I would bet it's advanced too much.
Old September 6th, 2007, 03:43 PM   #6
booblinker
Sore and Tired 24/7
booblinker's Avatar
It had a fresh top end a few years ago, but it has hardly been ran since.
i put a motor i had sitting in my garage, that came out of a good running bike so Timing should be good, but guess i should check it.
I didn't pull it since. I'll have to check that
Old September 6th, 2007, 03:58 PM   #7
Motor Slut
Motor Slut's Avatar
2stroke....
Bog means too rich, or the power valve isn't working, or the compression is low, or the reeds are shot, or the timing is off, or the carb isn't right.
Old September 6th, 2007, 05:18 PM   #8
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
I only have one thing to add. if its a OLD factory style exhaust its most likely plugged from oil caked over the holes on the spark arrester. pull the exhaust and stick a garden hose on the engine side and see if water comes out the other end. I bet its barly a trickle.
Yetti
Old September 6th, 2007, 05:26 PM   #9
booblinker
Sore and Tired 24/7
booblinker's Avatar
Its an aftermarket pipe, but it does have the factory silencer, and a spary spark arrestor on it.
Old September 6th, 2007, 07:42 PM   #10
busyfixin
Balls Deep
busyfixin's Avatar
could be lean as well if its way to lean.
check the plug.
Old September 22nd, 2007, 05:01 PM   #11
88mudder
In the band!
its runnin too rich, get the carb rejetted.
Old September 24th, 2007, 01:51 PM   #12
bikerted86
sounds rich to me too, check with the pipe manufacturer and see what they suggest. Most 2 stroke always come way too rich from the factory
bikerted86 is offline   Reply With Quote
Page generated in 0.27431 seconds with 59 queries
