mustang t-5 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 5th, 2007, 08:14 PM   #1
88mudder
In the band!
Default mustang t-5
looking to swap in a t-5 into my b2...
did they make hydraulic versions? I heard they had them 1993 on down in the foxbodies..?
Old September 5th, 2007, 10:42 PM   #2
FORD FLARESIDE
Headed to Nationals 2017!
FORD FLARESIDE's Avatar
1991 or 92 was the first years of the roller motors. I think 4K will get you one with 400 hp from Ford Motor Sports racing.
I'm running a similar motor in my Flareside.
Old September 5th, 2007, 10:57 PM   #3
bigblocked
bigblocked's Avatar
1985 and newer 5.0 HO's were all roller motors (85 was last year of carbs) but I think he's asking about the clutch mechanism. All FOX and SN95 cars had cables. There are nice after market kits that have billet bellcranks and firewall adjustable cables. Typically they'll last for a long time and can handle high rate pressure plates. I would definately prefer that style over a hydraulic setup.
bigblocked is offline   Reply With Quote
Old September 5th, 2007, 11:00 PM   #4
88mudder
In the band!
thanks for the info..and yes i was asking about the clutch.
Old September 5th, 2007, 11:02 PM   #5
88mudder
In the band!
I would rather prefer a hydraulic setup on mine because i already have the clutch master cylinder and line there...all i would need to do is adapt my line to the t-5 somehow. Does anyone kno how to convert a t-5 to a hydraulic setup? What slave cylinder works?
Old September 6th, 2007, 06:53 AM   #6
FORD FLARESIDE
This is probably true in the HO's in the Mustangs, but I know the truck 302's (5.0) did not go rollers until 91 or 92 when they went to multiport fuel injection.
Old September 6th, 2007, 04:43 PM   #7
bigblocked
bigblocked's Avatar
Right on. Just mentioned the Mustang motors because he mentioned Mustang in his title.
Old September 6th, 2007, 08:00 PM   #8
busyfixin
Balls Deep
busyfixin's Avatar
you could probably use parts from a jeep, or s-10 to get the hydraulic parts.
Old September 7th, 2007, 12:14 PM   #9
Never_Evil
A 1987 Ford F150 has an external slave cylinder to push on the clutch fork. I have/had one on my 4x4 that had a I6 and a 4sp. The bell housing is also removeable so if you find a 87 in a yard you can buy the bell and get the bracket that holds on the external slave.
in 1988 they went to an internal slave with the 5sp and that didnt have a removable bellhousing because it was made by mazda.
Be careful using the mustang T-5. The shifter is at the rear of the transmission. In a truck the shifter is in the middle of the transmission. Make sure you get your measurements right so you dont get surprised.
Old September 8th, 2007, 02:02 AM   #10
Jrod-13
poser wheeler
you have to be kinda carefull with that though, because there is no set year.. you could have a 5 speed in 87, and a 4 speed well into the 90's, other than that though, as you sad, 4 speeds have external slave, and 5 speeds internal slaves, unless they were behind a diesel or big block.
Jrod-13 is offline   Reply With Quote
Old September 15th, 2007, 06:26 PM   #11
88mudder
In the band!
dont need this anymore
Page generated in 0.32161 seconds with 56 queries
