Metal to Metal Noise - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 1st, 2006, 10:35 AM   #1
Pongking23
CHOP'S Idol
Pongking23's Avatar
Send a message via AIM to Pongking23
Default Metal to Metal Noise
well the latest noise comming from my Jeep.....i know its a noise and i drive a Jeep and a noise isnt anything new......but the latest is a metal to matal squeak it sounds like to pieces of metal were rubbing up against each other. I thought at first it was the hood rubbing up against the safety latch, but thats not it, it sounds more like its comming from the axle or the wheel assembly.
The weird thing is, is that it starts after it is really cold outside, and after the Jeep warms up a little bit and i start to drive it, it slowly goes away. I dont know if it is a wheel bearing or something along those lines...just want to avoid something major, because it has been getting worse and worse.
ooo yea, it doesnt happens when the temperature isnt below freezing?!?!?!?!?!
Pongking23 is offline   Reply With Quote
Old March 1st, 2006, 10:44 AM   #2
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
u-joint? center ball on front DS CV joint?
Old March 1st, 2006, 10:55 AM   #3
Bones
Bones's Avatar
metal to metal that changes with temp... probably not a good sign. Does it sound rotational at all?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old March 1st, 2006, 01:14 PM   #4
Pongking23
CHOP'S Idol
Pongking23's Avatar
yes it shounds rotational....kinda i guess. Its pretty hard to explain. It happens when i start moving, when i move faster it sounds faster and when i slow down it slows down......
Old March 1st, 2006, 01:35 PM   #5
shawn
Resident HVAC/R Jambi
shawn's Avatar
ujoint
Old March 1st, 2006, 01:39 PM   #6
Pongking23
CHOP'S Idol
Pongking23's Avatar
woulds it be a u joint, because its not a knock or anything like that, it sounds like more of a screaching noise, like you would take 2 pieces of sheet metal and rub the ends together.....i have no idea
Old March 1st, 2006, 01:40 PM   #7
Pongking23
CHOP'S Idol
Pongking23's Avatar
ill get under it today and see if there is any play in the drive shaft and whatever, ill just get under by the drive shaft and check things out
Old March 1st, 2006, 01:41 PM   #8
Check the front CV joint in the driveshaft. They are notorious for drying up and going bad..
Old March 1st, 2006, 01:49 PM   #9
PavementPounder
PavementPounder's Avatar
Yes, driveshaft u-joints are more likely to make a noise like that as opposed to axle joints.
Old March 1st, 2006, 02:06 PM   #10
Pongking23
CHOP'S Idol
Pongking23's Avatar
ok, i will get it checked out.....
Old March 1st, 2006, 10:09 PM   #11
JEEPR
Playing Possum
JEEPR's Avatar
I think it's called "angry sparrows" noise. If that sounds right, it's probably the front CV joint.
JEEPR is offline   Reply With Quote
Old March 1st, 2006, 10:16 PM   #12
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
u joint
Yetti
Old March 1st, 2006, 10:26 PM   #13
BigBlkYJ 355
U-Joints Fear Me
BigBlkYJ 355's Avatar
might also want to check the wheel bearings...
Old March 3rd, 2006, 09:50 AM   #14
RICK
Retired double dipper
RICK's Avatar
Yup.
Go to www.Jeepsunlimited.com and search for Angry sparrows.
It's a common problem with the front CV joint drying out.
I had two front driveshalfts replaced on my 99TJ under a "secret" warranty issue.
RICK is offline   Reply With Quote
Old March 3rd, 2006, 06:37 PM   #15
Pongking23
CHOP'S Idol
Pongking23's Avatar
if i get it replaced with my mechanic.....how much am i looking to spend here.....he is very honest and we have given him a lot of business, so he usually cuts the labor in half.......so how much is a part or rebuild or whatever need to be done with the front CV?
Old March 5th, 2006, 11:45 AM   #16
Tonka
Tonka's Avatar
my advice:
keep and rebuild the stock front shaft as a spare.
Get an aftermarket front driveshaft.
with the short armed suspension, and low pinion front axle, the tj driveshaft is pretty vulnerable.
Old March 5th, 2006, 07:12 PM   #17
Here's everything involved, including part numbers and prices, and a nice how to with pictures...
http://www.stu-offroad.com/axle/driv...iveshaft-5.htm
Basically, to service the double cardan joint, you are replacing two U-joints in the standard method, and replacing the centering yoke.
Old March 6th, 2006, 09:34 PM   #18
Pongking23
CHOP'S Idol
Pongking23's Avatar
thanx guys for all of your help!!!
Page generated in 0.25729 seconds with 77 queries
