Transmissions to a Inline 6? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 4th, 2007, 02:28 PM   #1
rrcarewdodge
Git Some!!
rrcarewdodge's Avatar
Default Transmissions to a Inline 6?
I have a 94' f150 2wd I6, wanting to know if the c-6 will bolt right up to the I6 or not? If not does anyone know what other trannies do?
rrcarewdodge is offline   Reply With Quote
Old September 4th, 2007, 03:00 PM   #2
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
300 six shares the same bellhousing pattern as any small block Ford: 289 V8, 302 V8, 351 V8, and 250 I6. it will bolt up to it, but you need a neutral balanced flywheel/flexplate. The 300 will have a larger tooth count flywheel/flexplate and you could probably get the 250 flywheel/flexplate to work if you needed the smaller diameter one, but don't hold me to that.
Old September 4th, 2007, 03:12 PM   #3
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
do not confuse the 351/w and 351/c with the 351/m/400 this is actually a big block.
Old September 4th, 2007, 03:53 PM   #4
Captain Ledd
Ranger Addiction?
Ahh! yes, thanks for that!
Old September 5th, 2007, 11:15 AM   #5
Defacater
Rubber Side Down
Defacater's Avatar
Depending on the c-6, some were built with a BB bell housing and some with a SB bell housing. A c-4 would bolt up to the 300, a 4R70W, or a zf 5-speed, i am not sure what you had or if you are switching to manual or auto.
Grant
Defacater is offline   Reply With Quote
Page generated in 0.17693 seconds with 38 queries
