what does the 2L or 2H mean at the end of the #s stanped on the ring gear mean? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 2nd, 2007, 12:31 PM   #1
luvitmyjeep
broken
luvitmyjeep's Avatar
Default what does the 2L or 2H mean at the end of the #s stanped on the ring gear mean?
after ripping off 8 teeth on my ring gear i found another one for $50 it came on what looks like a factory tracllok carrier but the spyders dont spin are they sapost to move freely? all the #s on the ring gear are the same execpt the date and at the end of the #s the one i took off has 2H and the new one says 2L what does this mean? next can i still use my old pinion or should i change that too? i don't see any damage on it.
thanks aron
ID:	14423   Click image for larger version
ID:	14424   Click image for larger version
luvitmyjeep is offline   Reply With Quote
Old September 2nd, 2007, 01:58 PM   #2
luvitmyjeep
broken
not so i just talked to someone at auto zone and he said it wouldn't work due to high and low pinion. please tell me he is wrong tho it makes sence. is ther a way to make it work? thanks aron
Old September 2nd, 2007, 02:14 PM   #3
Flexin' XJ
Flexin' XJ's Avatar
If these are for the dana 30, then most likely the L is for low pinion, and H is for high. And no, they cannot be interchanged.
Flexin' XJ is offline   Reply With Quote
Old September 2nd, 2007, 02:15 PM   #4
luvitmyjeep
broken
sorry they are out of a d35 thats why i dont understan i didn't think there was a high and low.
Old September 2nd, 2007, 02:42 PM   #5
luvitmyjeep
broken
i just checked the two side by side and the teeth go the same way as do the pinion gears. doesn't low pinion just mean that it is a reverse cut? witch side by side they would go oppisite ways? someone please school me
Old September 2nd, 2007, 02:52 PM   #6
mpwal099
Stick it up your ass
mpwal099's Avatar
2H = open diff
2L = a locked diff or limited slip.
As long as it is the same gear ratio you should be fine.
Last edited by mpwal099; September 2nd, 2007 at 02:54 PM. Reason: got my alpahbet mixed up~
mpwal099 is offline   Reply With Quote
Old September 2nd, 2007, 03:05 PM   #7
luvitmyjeep
broken
Originally Posted by mpwal099 View Post
2H = open diff
THANKYOU!!!!
guess thats why a cupple whole shots shredded the 2H guess that means i have to chang the pinion gear too
Old September 2nd, 2007, 04:57 PM   #8
2H = open diff
Hmm, I'm not an expert, but I wouldn't mix and match.. they are a set, and need to be set up as such.
Old September 2nd, 2007, 05:37 PM   #9
mpwal099
mpwal099's Avatar
I'm no expert either, but wouldn't this just be like adding an aftermarket locker?
Old September 2nd, 2007, 06:04 PM   #10
clarkstoncracker
lol
clarkstoncracker's Avatar
The pinion and gears have been "broken in" together. If you replace the gears, the pinion will not mate perfectly to them.
Nothing to do with a locker.
Old September 2nd, 2007, 09:40 PM   #11
luvitmyjeep
broken
thanks to all. i will keep them together.
Old September 3rd, 2007, 09:43 AM   #12
mpwal099
mpwal099's Avatar
AHHHHHHH I wasn't realizing Jesus was talking about the pinion. :miff: But yeah they would need to be kept/ replaced together.
Page generated in 0.25013 seconds with 60 queries
