clean 70's ford interior parts *$150 for all of it* - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 30th, 2007, 11:46 PM   #1
busyfixin
Balls Deep
busyfixin's Avatar
Default clean 70's ford interior parts *$150 for all of it*
id like to get rid of some really nice parts before i mess them up.
i pulled these from a 76 f-150 that i needed the axles from.
very nice dash assembly black.
has a muzzy broadhead sticker on it, and two holes drilled for switches. otherwise just about perfect. includes everything but the radio, as it was missing. the pad across the top is the best original one i have ever seen. (repro pads are about $250 last time i looked) heater controls and cables also included
$150 obo
wiper motor assy. (no wipers or arms)
pretty nice, i did not check it before i pulled it, but was told it worked.
$25
steering column and wheel.
nice condition, black in color, wheel is a little dirty
$35 SOLD
heater box assy.
all flappers move freely, had a heater core put in it sometimes, and does not leak. has a couple small corners broken off, but will work much better than one with a boot kick hole in it.
$30
interior wiring harness
this is just about the cleanest old truck harness ever. all the clips came apart nicely, broke one clip out of habit (stupid ford connectors are always stuck) then realized they would come apart easily. i think only one connector was cut ever, for the radio i think. there is one section of burned wires that i didint see when i took it out, and im not sure where it goes now, so im not sure why it was burned, but wouldnt take alot of work to repair it.
we all know how hard it is to find a nice wiring harness that hasnt been spliced and taped 30 times. this would be really nice to replace that hacked up one in your truck. comes with the antenna wire too.
$62
ID:	14339   Click image for larger version
ID:	14340   Click image for larger version
ID:	14345   Click image for larger version
ID:	14349   Click image for larger version
ID:	14351   Click image for larger version
ID:	14352   Click image for larger version
Old August 30th, 2007, 11:55 PM   #2
bigjay
The Man Myth And Legend
bigjay's Avatar
Location: i can piss on the allegan and barry county line at the same time.. ...
was there a cab???
bigjay is offline   Reply With Quote
Old August 31st, 2007, 12:28 AM   #3
busyfixin
Balls Deep
busyfixin's Avatar
nope, all the parts were held to in the right positions by magnetic fields.
yes, there was a cab, but it is pretty crappy, had new floors welded in a while ago, already rust around them, a bubble sunroof, rear cab mounts are wasted.
i have another that may be better. a guy i know used to have a spare stored in a shed out back that was mint, i could probably track one down if you need one. there are a bunch of the guys around here running them.
Old September 6th, 2007, 10:31 PM   #4
busyfixin
Balls Deep
busyfixin's Avatar
bump
Old November 15th, 2007, 06:31 PM   #5
busyfixin
Balls Deep
busyfixin's Avatar
bump everything still available, get your plow truck fixed up!
Old December 9th, 2007, 03:56 PM   #6
busyfixin
Balls Deep
busyfixin's Avatar
ttt
Old January 17th, 2008, 07:18 PM   #7
busyfixin
Balls Deep
busyfixin's Avatar
again
Old January 17th, 2008, 09:36 PM   #8
secondechomatt
secondechomatt's Avatar
how much for just the gauge cluster/surround, and passenger side dash surround?
ohh and the hvac controls.
thanks
secondechomatt is offline   Reply With Quote
Old January 17th, 2008, 09:52 PM   #9
IDIeselman
IDIeselman's Avatar
If the colum is tilt It's sold.
Old January 20th, 2008, 06:50 PM   #10
busyfixin
Balls Deep
busyfixin's Avatar
no tilt. i wish it was, but im sure you know how rare they are in pick-ups.
pm sent about the dash.
Old January 20th, 2008, 08:24 PM   #11
IDIeselman
IDIeselman's Avatar
[QUOTE=busyfixin;909728]no tilt. i wish it was, but im sure you know how rare they are in pick-ups.
Yes but also rare is a stick in a ranger package. Just thought I might get lucky.
Old January 20th, 2008, 10:06 PM   #12
busyfixin
Balls Deep
busyfixin's Avatar
true.
Old February 20th, 2008, 01:48 PM   #13
busyfixin
Balls Deep
busyfixin's Avatar
up again, no-one has an old ford plow truck?
offers?
Old February 26th, 2008, 01:46 PM   #14
busyfixin
Balls Deep
busyfixin's Avatar
ttt, $150 for all of it?
Old February 26th, 2008, 01:52 PM   #15
lil monster
BUILT NOT BOUGHT
lil monster's Avatar
Send a message via Yahoo to lil monster
I'm wheelin a stick in a ranger pkg, but I need inner door panels. anything good?
lil monster is offline   Reply With Quote
Old February 26th, 2008, 01:58 PM   #16
busyfixin
Balls Deep
busyfixin's Avatar
ill check, but im pretty sure the PO kept the door panels from this one. ill check today.
Old February 26th, 2008, 02:48 PM   #17
busyfixin
Balls Deep
busyfixin's Avatar
i do not have any good door panels.
Old February 27th, 2008, 01:11 PM   #18
lil monster
BUILT NOT BOUGHT
thanks for checkin
Old January 23rd, 2009, 11:57 PM   #19
bigbad51ford
bigbad51ford's Avatar
Send a message via MSN to bigbad51ford
How much for the black dash pad? pm me and let me know
bigbad51ford is offline   Reply With Quote
Old January 24th, 2009, 09:45 AM   #20
big_ol_bronco78
Psalm 40:2
big_ol_bronco78's Avatar
Pm sent
big_ol_bronco78 is offline   Reply With Quote
Page generated in 0.84909 seconds with 84 queries
