tierod reamers? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 28th, 2007, 08:07 PM   #1
busyfixin
Balls Deep
busyfixin's Avatar
Default tierod reamers?
i know everyone seems to swap to the one ton chevy tie rod end size, but what size is it, and how do i know what size i have already? i have several fords and dodges that i need to know what size i have now, as i am not buying a ton of new tie rod ends. well, i dont want to anyway, and the ones i have now are good. also who sells the reamers, and how much do they usually cost.
Old August 28th, 2007, 09:02 PM   #2
http://www.pirate4x4.com/forum/showthread.php?t=608801
Old August 28th, 2007, 10:34 PM   #3
PavementPounder
PavementPounder's Avatar
http://www.jcroffroad.com/Merchant2/...tegory_Code=S6
Old August 28th, 2007, 11:22 PM   #4
junk90xj
ALLPRO AUTO
junk90xj's Avatar
5/8drill bit from local hardware and i 5/8 taper reamer from snap-on tools.
reamer cost 30 bucks
http://www.apalansing.com/
Old August 29th, 2007, 12:34 AM   #5
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Yeah don't buy the stuff from us. It's marked up high enough we don't have to carry it in stock.
If your using the Chevy 1/2 ton-3/4ton ends your looking for a reamer with 1.5" of taper per foot. This works out to like 7.12 degrees.
- If your looking for the best... this is what you want. We have had the same one for almost 2 years now. It's just getting time for a new one.
Part # R8201 http://www.stockcarproducts.com/susp13a.htm
- Another good option, a little cheaper.
http://www.goodson.com/store/templat...php?IID=4488&&
-Bottom line on a machine bit.
http://cgi.ebay.com/ebaymotors/1-1-2...spagenameZWD1V
-The Snap on one (part R121) is actually a 7 degree reamer. It's also a cleanup reamer that is really meant to be used by hand to clean up tapers. It is the cheapest option, will last for a dozen + reams when used with a drill and a good cutting fluid, and is close enough to 7.12 to work fine (we are doing this by hand remember.)
For some reason it's marked wrong at a 1.90 currently... usually it's $46.
http://buy1.snapon.com/catalog/parts...&group_id=8957
JcrOffroad
Zoom Zoom!
Old August 29th, 2007, 06:14 AM   #6
nixxerRsixxer
Homewrecker
nixxerRsixxer's Avatar
tired? thats just the handle.. http://buy1.snapon.com/catalog/item....store&tool=all
nixxerRsixxer is offline   Reply With Quote
Old August 29th, 2007, 06:45 AM   #7
Cartman
Can't lose with 42s
Cartman's Avatar
The snappy one gets shit reviews. Research it. The guys on pirate say it doesn't last
Dizzle, the chevy 1 ton TREs are like $10 a piece...cheapass I'll even buy some if you do cuz I need to redo my steering too
They are way more beef than any ford/dodge ones I bet too
Cartman is offline   Reply With Quote
Old August 29th, 2007, 07:06 AM   #8
nixxerRsixxer
Homewrecker
Page generated in 0.30969 seconds with 47 queries
