HVAC switches to defrost under load. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 28th, 2007, 05:02 PM   #1
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Default HVAC switches to defrost under load.
Here's my other issue on my truck ('01 Dodge Ram 4x4).
Say I have the A/C pointing at my face. If I'm on the freeway and give it 3/4 throttle so the load increases on the engine, the vacuum change causes my HVAC to switch to defrost.
I've checked with tech manuals and it is supposedly a common problem says to replace both check valves on the vac lines near the intake manifold.
I pulled both valves and checked them and they hold vacuum. The lines don't seem to have any leaks either.
Any help?
Old August 28th, 2007, 07:11 PM   #2
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Ask PP he knows everything.
Old August 28th, 2007, 09:36 PM   #3
user name
keep your stick onthe ice
user name's Avatar
:tonka:
Old August 28th, 2007, 09:38 PM   #4
user name
user name's Avatar
is there a vac res to hold vacuum to the hvac under at wot?
Old August 28th, 2007, 09:49 PM   #5
Mclovin
"The Situation"
Mclovin's Avatar
your truck just wants to make sure you have a clear view when going that fast
Old August 28th, 2007, 10:39 PM   #6
GreaseMonkey
Pew pew!
Not that I can see. I'll have to pull up some diagrams tomorrow in the auto building computer lab and see if there's anything.
Old August 29th, 2007, 11:25 PM   #7
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Usually it means the res is cracked, or disconnected.
Old August 29th, 2007, 11:40 PM   #8
GreaseMonkey
Pew pew!
Where's the res located?
Old August 30th, 2007, 08:21 AM   #9
Hmm, my 96 ram does it also, its really annoying..
Hoping muddypaws will post some purty diagrams....
:dunie:
Page generated in 0.31738 seconds with 50 queries
