Coverting to manual... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 28th, 2006, 11:18 AM   #1
SS
Bananarama!
SS's Avatar
Default Coverting to manual...
The classic question:
How hard would it be to convert my 95 dodge ram with the 318 over to a manual?
Which trans would be used? Would the t-case bolt right up to the manual trans?
What about rearranging stuff in the interior? Holes would obviously need to be cut... Would this interfere too much with the 4wd shifter?
I'm not a huge fan of the slush box..
-Jer
Old February 28th, 2006, 05:41 PM   #2
user name
keep your stick onthe ice
user name's Avatar
i think it would be best to find a truck with a stick and get all the stuff to do it out of that. you need lots of parts to make the stick and new would probly be real expesive. or just buy a truck with a stick
Old March 1st, 2006, 02:45 PM   #3
noodles
give 'er sh*t ay?
noodles's Avatar
there would be alot of work, the shifter for the 4x4 would have to be new. im not positive but you might get away with enlarging the whole for your 4wheel shifter now. to get the manual in. ive got a manual that i can look up what stuff bolted together.
Old March 14th, 2006, 12:29 PM   #4
Toivo
Feel lucky?
Toivo's Avatar
Default BAD IDEA lol
I would HIGHLY advise against a manual trans...HIGHLY...you can build your automatic up to out perform and outshift a manual trannyed truck..as well as not have to deal with all the bullshit (and co$t) of switching to a manual trans...youll prolly have to switch over the computer or some crap like that as well as find a way to put the damned clutch pedal in the truck...my '72 came with a stick and diviorce t case...right into the scrap heap went the stick lol but as always with any vehicle...do what ever you damn well please!
Old March 14th, 2006, 01:22 PM   #5
PavementPounder
PavementPounder's Avatar
Yeah, just buy a manual truck.
Old March 14th, 2006, 01:40 PM   #6
Monster4.0
Monster4.0's Avatar
To answer some of your questions a Getrag or a NV4500 would work. Depending on if you wanted a creeper gear or not. I think a NP435 would work too if you machine a cps notch for it.
I know in the 2wd version the trans cross member is different.
You would need the pedal assy, slave cylinder, trans, all the clutch parts and probably a whole slew of other things I'm forgetting.
I'm assuming you have a 46RH it is not the most desirable trans "my trucks on its fifth one" in 200,000 miles.
Overall I'd go against the crowd but first ask yourself....Are you going to keep the truck long term?
If you are I'd put the stick in it. If you replace/rebuild the auto trans it will still be iffy at best.
I thought about going to a 727 for a stronger trans but I don't want to loose my overdrive.
Old March 14th, 2006, 01:43 PM   #7
Monster4.0
Monster4.0's Avatar
Your computer should be ok because your trans is hydrolicly(sp) controlled.
You might have to figure something out for the nuetral saftey switch also.
Old March 24th, 2006, 12:33 AM   #8
noodles
give 'er sh*t ay?
noodles's Avatar
it might screw up the OD, or when he shifts in to that because the computer doesnt control it anymore.. but that owuldnt be that big of an issue, i woudl think. i lost my first 46rh at 220000 miles, and i was very happy how long it lasted. i think if you are going to buy a truck to get parts why dont you just go with that truck. but its your own and if you want to go for it.. do it..lol
Page generated in 0.26482 seconds with 47 queries
