Question about a Dodge Truck - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 27th, 2007, 08:19 AM   #1
gary
Default Question about a Dodge Truck
i have the chase to buy a 1991 Dodge 2500 4x4 does any one know what axles and trans this truck would have. Thank You It is an automatic. It is a gas engine. I want to put the axles in my jeep and see if the trans will fit on 360 with a d300 t case
gary is offline   Reply With Quote
Old August 27th, 2007, 09:15 AM   #2
Cartman
Can't lose with 42s
Cartman's Avatar
King pin dana 61 front....If you want to put gears in it they sell a spacer so you can run dana 60 stuff, not a very desirable front for wheelers but the spacer lets you atleast have some gearing options
Dunno about the rear, probably dana 60/70
Cartman is offline   Reply With Quote
Old August 27th, 2007, 09:30 AM   #3
Monster4.0
Monster4.0's Avatar
Is it a stick or auto?
Old August 27th, 2007, 10:49 AM   #4
Cartman
Can't lose with 42s
Cartman's Avatar
If it were a stick it would be the shitty getrag 5sp with a freakin overdrive for a 1st gear...NV4500 on the 94-ups
Old August 27th, 2007, 04:30 PM   #5
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
Front may be D60, depending on the ratio, some ran 4.10s
Old August 27th, 2007, 06:05 PM   #6
user name
keep your stick onthe ice
user name's Avatar
gas or diesel? gas should be an a518rh the diesel I'm not really sure.
Old September 11th, 2007, 04:06 PM   #7
beejers
always building
beejers's Avatar
check numbers on the axle.
http://www.pirate4x4.com/tech/billav...%20Shafts.html
beejers is offline   Reply With Quote
Old September 11th, 2007, 10:55 PM   #8
user name
user name's Avatar
it should have a a-518 trans that will bolt to any mopar small block. if the truck has a 318 you will need a different torque converter behind a 360. I have no idea about the dana 300. It could have a dana 60 or chrys 9 1/4 rear and the possibility of a dana 60 or 44 front.
I assumed you were using chrysler 360 not an AMC 360 which is probly wrong
Page generated in 0.28604 seconds with 47 queries
