Ram wheel bolt patterns - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 27th, 2007, 12:30 AM   #1
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Default Ram wheel bolt patterns
Wondering.....will a rim off a older, say 80's Dodge half ton go on a 96 half ton?
I wanna borrow someones tires...just really don't want to go through the trouble of mounting and all that jazz.
Old August 27th, 2007, 10:16 AM   #2
Cartman
Can't lose with 42s
Cartman's Avatar
gotta watch this...
some of those old 80s dodges had 5x4.5, forget the year breaks and stuff
then they switched back to 5x5.5 at some point which is what your 96 is...
Cartman is offline   Reply With Quote
Old August 27th, 2007, 10:26 AM   #3
Monster4.0
Monster4.0's Avatar
There might be an issue with the calipers hitting the rims. I dunno for sure, but you might want to look, and see what you have for clearance.
Old August 27th, 2007, 05:41 PM   #4
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
Dodge used 5 on 4 1/2" back in the mid to late 70's, and 80 only, IIRC (with the 203). The bolt pattern is the same 5 on 5 1/2" for the rest of the '80s, but the '96 has about 1 1/2" more backspacing, and most likely is a 16" wheel. I'm not sure if 15s will fit on a '96. I have been told the center register is smaller on the '96 as well, but I haven't personally checked that.
Old August 27th, 2007, 05:48 PM   #5
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Shit...forgot about the 16 inch rim. hmmm......gotta figure something out soon. I'm going to steal some tires soon and I want to make sure they'll fit.
:tonka:
Old August 27th, 2007, 05:50 PM   #6
dline
dline's Avatar
my buddys 99 ram 1500 has 15" rims on it.
dline is offline   Reply With Quote
Old August 27th, 2007, 05:50 PM   #7
Toivo
Feel lucky?
Toivo's Avatar
yes my tires will fit dammit. cut them up at all and its your ass!
Old August 27th, 2007, 05:53 PM   #8
nixxerRsixxer
Homewrecker
nixxerRsixxer's Avatar
the 96-01 rams have 5x5.5 and will fit a 15" wheel i had both steel and aluminum on my ram at one point..
and as said before 81-95 rams 5x5.5 .. wheels will stick out a bit more due to the wider wms on the newer rams..
and i do remember something being funny about the center bore for the unit bearings.. cant remember if they ran small or if they ran large.. but i never had problems with any of the wheels i ran :/
nixxerRsixxer is offline   Reply With Quote
Old August 27th, 2007, 05:55 PM   #9
deuce228
Redneck Poser
deuce228's Avatar
I posted a good link that will detail the bolt patterns a while back.
http://www.stagewest4x4.com/store2/s...lt-pattern.htm
Old August 27th, 2007, 06:05 PM   #10
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
New question....
Will 33's fit a stock 96 1500? :tonka:
Old August 27th, 2007, 06:13 PM   #11
Toivo
Feel lucky?
Toivo's Avatar
doubtful....try it...I know they fit on craigs black truck, but they rubbed at full lock
Old August 27th, 2007, 07:02 PM   #12
user name
keep your stick onthe ice
user name's Avatar
if you cut the front bumper area. I think jons will probly rub on your truck as they are 13" wide and sit out a lot wider cant remember if that is more or less offset
Old August 27th, 2007, 07:08 PM   #13
nixxerRsixxer
Homewrecker
Originally Posted by muddybawls
New question....
with the right backspacing they will.. problem is when the wheel turns into the fender area by the door.. bumper is not a problem..
Old August 27th, 2007, 07:23 PM   #14
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
I don't need it to turn sharp. Needs to go 2 runs in the mud drags.
Old August 28th, 2007, 08:12 AM   #15
Cartman
Can't lose with 42s
Cartman's Avatar
Originally Posted by MuddyPaws View Post
New question....
If they dont I have some 2500 springs that will give you some lift up front PM me if intrested
Old August 28th, 2007, 08:29 AM   #16
nixxerRsixxer
Homewrecker
than it shouldnt be a problem i borrowed my friends 33x12.5 TSLs on wagon wheels with a ton of backspacing back when i did a couple silver lake runs with my ram when it was stock .. worked fine (till i did test hill and WOT and at the top turned left/right for some reason and took a lug off one :tonka: )
Old August 28th, 2007, 09:50 AM   #17
busyfixin
Balls Deep
busyfixin's Avatar
should be fine.
Old September 6th, 2007, 10:50 PM   #18
Mclovin
"The Situation"
Mclovin's Avatar
New question....
YES ! i know for a fact that 35's with fit that body style with no lift and minimal rubbing..
Old September 6th, 2007, 11:14 PM   #19
PavementPounder
PavementPounder's Avatar
Bullshit. 315's rubbed significantly before lock on my 2500 when it was sitting level.
Old September 6th, 2007, 11:36 PM   #20
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
I would prefer that you shut the -fuck up and stay out of my threads. No one gives a shit what you think.
Page generated in 0.28493 seconds with 83 queries
