lincoln locker - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 26th, 2007, 11:08 AM   #1
dirtrider
Dopey
dirtrider's Avatar
Default lincoln locker
can you weld your spider gears while still in the housing or do you need to remove the carrier to do this? its a dana 44 on a cj7 if anyone has pics or suggestions that would be a great help.
dirtrider is offline   Reply With Quote
Old August 26th, 2007, 11:23 AM   #2
rargreen
88
rargreen's Avatar
You can weld them in the housing but it is not very easy & it is real hard to clean before and after welding. I would take the carrier out & be careful not to get it to hot.
rargreen is offline   Reply With Quote
Old August 26th, 2007, 11:48 AM   #3
Cartman
Can't lose with 42s
Cartman's Avatar
You can do it both ways, we always use about a can of brake cleaner to make sure all the oil is off of the gears....some compressed air to dry the brake cleaner...then get er done with 6011 and then cap it with 7018. Melt the gears into the side of the case and don't be afraid to lay it on thick. Haven't broke one yet. If you want you can take out the diff and heat it up with a torch and then weld it, but make sure you do something about the carrier bearings, they will get hella hot and might get some splatter in em..
When I do them inside the housing, we always chip off as much slag as possible, run it for 1hr or so, change the fluid and then its good to go.
Cartman is offline   Reply With Quote
Old August 27th, 2007, 08:44 PM   #4
Motor Slut
I put the Ick in Dick.
Motor Slut's Avatar
Only do this if you never want to use the carrier for anything else.
I just weld the gears together. 8 welds and you're done, and it is completely reversible.
Old August 27th, 2007, 08:59 PM   #5
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Have you looked into mini spools at all?
Old August 27th, 2007, 09:01 PM   #6
dirtrider
Dopey
dirtrider's Avatar
it has 2.72's so when i go to my 4.10's or higher im going to need a new carrier any ways, my only concern was if it breaks when im driving how much ill destroy. I saw some pictures where they welded a plate i the middle of all 4 spiders
Old August 27th, 2007, 09:12 PM   #7
sglide
co captain of cubes pants
sglide's Avatar
if your going to remove the carier to weld it, tack all gears together while still in the housing first so they dont draw while wile welding and make it hard to impossible to get the shafts back in
sglide is offline   Reply With Quote
Old August 28th, 2007, 12:59 AM   #8
Pre4runner
Bike Dude
Pre4runner's Avatar
I welded mine in case... really quick job. I did run it a couple days and drained the fluid. Lasted 7 months then cracked, drove it another month with out a single problem. Just pulled it out this weekend to put some new gears in. Much better weld job this time round.
On my toyota i added a piece of steal to each side, that never failed me
Old August 28th, 2007, 07:08 AM   #9
Cartman
Can't lose with 42s
Cartman's Avatar
fo sho
I didn't mind sacrificing a carrier for mine though, stupid 3.92 and down carrier
Page generated in 0.30801 seconds with 50 queries
