MY low slung XJ *updates 9-20-08* - Page 6 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 18th, 2008, 09:30 PM   #101
Pre4runner
Bike Dude
Pre4runner's Avatar
The front axle is now prepped and ready for mock up. Because the waggy d44 is a low pinion i decided to cut the c's and rotate the housing to get some clearance as well as better drive shat angles. I also shaved some of the housing again but not as much as the rear.
Rotated it up to 15 degrees
Hopefully will have the axle under the jeep this weekend with some rollers so i can start fine tuning the suspension
Old November 18th, 2008, 09:38 PM   #102
Mud'N'Truck
I'll Finsh One, One Day
Mud'N'Truck's Avatar
Lookin good man, but gotta say it " Real wheelers run 60s".
You going to mounds turkey day?
Old November 18th, 2008, 09:48 PM   #103
Pre4runner
Bike Dude
Pre4runner's Avatar
I would if i had the money.... school full time leaves very little to play with. And so far i'm ahead after selling my axles so no money spent yet on the upgrade. I did just come across a great deal on a d60 and 10.25.... 3 weeks to late though. Unless someone wants to buy some d44's
most likely will not be at the mounds. Every ones rig is down right now.
Old November 19th, 2008, 08:18 PM   #104
Mud'N'Truck
Know how that is except im the only 1 down forsure, every one else in my group has a chance of being ready
Old November 21st, 2008, 11:26 PM   #105
Pre4runner
Bike Dude
Pre4runner's Avatar
I made my coil perches today and one upper control arm mount. Perches are real simple just notched some 5" x 2" x 3/16" tubing to center the pring over the axle. This gave me about a 2 inch stretch in the front.
Prepped the old leaf mount so i could add some 1/4" plate around it. The original idea was to drill and tap the bottom for a couple bolts.
Instead i decided to make a couple pieces to box in the perch, welded them to the axle the welded the 1/4" to the brackets and the perch itself
Torched out the driver side coil mount
Tacked in place with the 3/8" bridge for the UCA mount
The XJ will now have a 110" wheel base, 37's or 38's. Also bent the radius arms, lots of clearance now.
26" to the unirail and 22" to the bottom of the control arm mount with the axle's center line 18" off the ground.
Old November 22nd, 2008, 12:11 AM   #106
Mclovin
"The Situation"
Mclovin's Avatar
what tires are you running ?? they look like mine did before i cut em ? if you have a groover Cut em up like mine.. they work great !
Old November 22nd, 2008, 05:15 PM   #107
Pre4runner
Bike Dude
Pre4runner's Avatar
the tires are old grand prix's they are just my left over spares. I'm looking for a set of 37's or 38's still
Old November 24th, 2008, 02:14 PM   #108
Pre4runner
Bike Dude
Pre4runner's Avatar
Checked for shock mounting points today
Old November 25th, 2008, 10:05 PM   #109
arcticjeff
Arcticjeff
arcticjeff's Avatar
Lookin great
arcticjeff is offline   Reply With Quote
Old November 26th, 2008, 01:37 AM   #110
Blackjackbender
looks good
any plans to tie the truss for the upper link any better?
Old December 23rd, 2008, 12:22 AM   #111
Pre4runner
Bike Dude
Pre4runner's Avatar
The truss for the upper link will get tied into the diff cover and i may run a tubular truss from coil bucket to coil bucket like on my last axle
Old December 23rd, 2008, 12:22 AM   #112
Pre4runner
Bike Dude
Pre4runner's Avatar
Decided to test fit tires tonight after working on justin's rig. SO i brok out the sawz all and went to town.
And this is what i am linda planning on doing with the rear fenders.
Rear also seems to set a little high so i will tweak with the shackle mounts to better their angle and lower it a bit.
Old December 23rd, 2008, 05:13 AM   #113
MidMichxj
Wrenchin for a livin
MidMichxj's Avatar
Looks good.
What are you going to do with your steering gear as the front stretch can cause clearance issues at the drag link and pitman arm?
MidMichxj is offline   Reply With Quote
Old December 23rd, 2008, 03:22 PM   #114
bitchofanxj
Are you cooool maaaann?
bitchofanxj's Avatar
That rear stretch is gonna look sweet as hell when finished! I've been looking at other Jeeps that are stretched in the rear and it makes me want to do it to my cherokee so bad. Do you think there will be any clearance issues with the gas tank? That's about the only issue I could think of.
bitchofanxj is offline   Reply With Quote
Old December 23rd, 2008, 06:22 PM   #115
Pre4runner
Bike Dude
Pre4runner's Avatar
Originally Posted by MidMichxj View Post
Looks good.
I have yet to really check the steering but i think i am still safe. I will be running a high steer arm for the drag link and hydrolic assist.
Gas tank has 4-5 inches of clearance currently but i will move it up so i don't have to run some major bump stops
Old December 25th, 2008, 12:53 AM   #116
bitchofanxj
I've got to say, I didn't like the stretched look of the rear wheel-wells at first but it definately has grown on me. This one is pretty cool.
Old December 25th, 2008, 01:11 AM   #117
Pre4runner
Bike Dude
Pre4runner's Avatar
that one isn't too bad... i think it would look better if the front wheel wells were larger. Its all about proportions
Old December 25th, 2008, 01:16 PM   #118
bitchofanxj
Yea, that wouldn't be too bad of an idea.
Old January 6th, 2009, 07:42 PM   #119
Pre4runner
Bike Dude
Pre4runner's Avatar
Back to work on the XJ! Been building LA'a for people.
Did some final welding and added some primer today.
Old January 24th, 2009, 09:49 PM   #120
Pre4runner
Bike Dude
Pre4runner's Avatar
Bead locks are welded up! Only ground one smooth so far.
White is pimp. Don't mind the steering and all that, its just for rolling the jeep around.
Page generated in 0.46620 seconds with 83 queries
