MY low slung XJ *updates 9-20-08* - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 4th, 2007, 10:41 AM   #41
Pre4runner
Bike Dude
Pre4runner's Avatar
Should be finished up today
Old November 29th, 2007, 04:31 AM   #42
Pre4runner
Bike Dude
Pre4runner's Avatar
This is what the final control arm ended up being
A couple fender shots since they seem to be popular
Old November 29th, 2007, 04:41 AM   #43
Pre4runner
Bike Dude
Pre4runner's Avatar
And I finally got around to mounting my winch on my bumper
Still keeps a really nice approach angle since i recessed it into the grill. I will be trimming that up tomorrow or make my own, we'll see
Also check out where i will be mounting the winch's box, i'll seal it up good first.
Old November 29th, 2007, 02:25 PM   #44
dune coon
do work
dune coon's Avatar
dune coon is offline   Reply With Quote
Old November 29th, 2007, 05:51 PM   #45
Fraser
Fraser's Avatar
what is involved in the body mounts and the crossmember? i see the plate box, but is there pieces welded/ attached to the framerail and the floorpan??
Old November 29th, 2007, 07:27 PM   #46
Pre4runner
Bike Dude
Pre4runner's Avatar
The inside of the uni rail and floor pan has been braced with some angle andits bolted into the stock location then welded in
Old November 29th, 2007, 07:45 PM   #47
Fraser
Fraser's Avatar
oh, ok the angle is welded to the side of the rail, on top of the mount, and the mount is welded to a piece of angle thats bolted on to where the stock crossmember was.. ok got it my brain and my eyes were havin trouble w/ that, so i had to ask did you build that tube crossmember too?
Old November 30th, 2007, 01:37 PM   #48
Pre4runner
Bike Dude
Pre4runner's Avatar
Yup its all home made, soon to be skids too
Old November 30th, 2007, 02:29 PM   #49
xj_man_646
Wheeler-less
xj_man_646's Avatar
Send a message via AIM to xj_man_646
What did you do for a trans x-member. I would do a subframe, and a trans x-member with more than just the stock 4 attachment points.
xj_man_646 is offline   Reply With Quote
Old November 30th, 2007, 10:48 PM   #50
Pre4runner
Bike Dude
Pre4runner's Avatar
Well my upper mounts are now a permanent part of the frame, and bracing that is on the inside. The cross member bolts between the arms are so you can drop the tranny without removing the suspension, it also braces the arm mounting points laterally
Old January 4th, 2008, 03:01 AM   #51
Pre4runner
Bike Dude
Pre4runner's Avatar
Installed JCR's 1-ton over the knuckle steering tonight and relocated the track bar, should work well. Will get some pics up tomorrow
Old January 4th, 2008, 03:45 AM   #52
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Yea, would like to see those pics. We were looking at the steering yesterday and couldn't see how it would clear the sway bar mount.
Old January 16th, 2008, 10:50 PM   #53
Pre4runner
Bike Dude
Pre4runner's Avatar
Well i finally have the whole thing streetable again. Finally put in a SYE, new gears in the front, solid cover to protect them, lock-rite and cleaned it up a bit.
The steering does have to be limited but its not much, so far i am happy with it. I do need to rebuild the flex joint on my trac bar though.
And i still need to remove and mount 2 of the tires back to the alloy rims
If you want some close ups of where and how it hits let me know
Old January 16th, 2008, 11:45 PM   #54
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Flexes nice.
Old January 19th, 2008, 01:39 AM   #55
Pre4runner
Bike Dude
Pre4runner's Avatar
It does but i want to try a few things to get the rear to flex a bit more, its still a little stiff, also need to make sure i have enough shock travel out back. Front shocks stop the drop just as the coil is fully unloaded, might make new mounts to lower the shocks a bit and then add limit straps.
Old January 19th, 2008, 11:07 AM   #56
nick_n_ii
nick_n_ii's Avatar
Send a message via Yahoo to nick_n_ii
I wondering how well you tube "flares" would work on a ZJ?????
nick_n_ii is offline   Reply With Quote
Old February 15th, 2008, 09:54 PM   #57
Pre4runner
Bike Dude
Pre4runner's Avatar
I'm sure they would for well, start cutting and welding
Old March 21st, 2008, 12:30 AM   #58
Pre4runner
Bike Dude
Pre4runner's Avatar
Well i yanked the axle.
Passenger LCA mount is a little bent out of shape, no idea why:hehe:
So i cut them off and will be making some brackets, or i may order some. I was also thinking of relocating the lower mounts a little higher and more behind the axle tube. I don't think i should have any problems doing this since i am running radius arms. This would also keep my wheel base right if i bend the arms for clearance. OPPINIONS PLEASE.
So untill i decide what to do there i started on the truss. Very simple. Pipe from spring bucket to bucket mount that arcs over the center section and has support brackets on a couple of th ediff bolts. Also went right through the passenger UCA mount.
I like the look better then most truss jobs, i'll be adding some ribs later i think
Old March 23rd, 2008, 02:39 PM   #59
Mud'N'Truck
I'll Finsh One, One Day
Mud'N'Truck's Avatar
Lookin good. Im just waiting on all my trusses to show up. And made a few yesterday.
Get this thing done and come to silver lake opening weekend
Old March 23rd, 2008, 09:45 PM   #60
bitchofanxj
Are you cooool maaaann?
bitchofanxj's Avatar
Does that diff cover come off very easily with those truss mounts on the bolts? I know in the past I've had issues with mine just getting hung up on the tie rod because the cover won't come forward enough to clear the gears. It could be the pictures but just an idea.
bitchofanxj is offline   Reply With Quote
Page generated in 0.30270 seconds with 83 queries
