Ball joint pref? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 24th, 2007, 06:49 PM   #1
Silver Bullet
Livin the American Dream
Silver Bullet's Avatar
Default Ball joint pref?
my buddy works for motown automotive and sells moog and spicer parts. my truck currently has moog but he is recommending me to go with spicer. what is your opinion and how much of a biatch is it to change the ball joints in a bronco.
Silver Bullet is offline   Reply With Quote
Old August 24th, 2007, 06:53 PM   #2
bigjay
The Man Myth And Legend
bigjay's Avatar
Location: i can piss on the allegan and barry county line at the same time.. ...
mooooooggggggg and eh . it not su bod
bigjay is offline   Reply With Quote
Old August 24th, 2007, 06:55 PM   #3
junk90xj
ALLPRO AUTO
junk90xj's Avatar
spicer is first then moog imo
http://www.apalansing.com/
Old August 24th, 2007, 07:09 PM   #4
Silver Bullet
any details on how to do i have had the spindle unbolted and that is as far as i have gone. and also do i need the "c" press to change the ball joints and while i have it torn down would you recommend changing the uppers also.
Old August 24th, 2007, 07:40 PM   #5
junk90xj
ALLPRO AUTO
junk90xj's Avatar
its foolish to do one and not the other.
you dont have to have the balljoint press but it sure will take an ass load of time off the job. id at least go to autozone and rent one to do the job then return it.
Old August 24th, 2007, 08:14 PM   #6
Silver Bullet
bump for any other comments
Old August 24th, 2007, 08:38 PM   #7
Silver Bullet
any tips on what i will be doing after i unbolt spindle?
Old August 24th, 2007, 08:49 PM   #8
needsrepair
needsrepair's Avatar
Default Free
Murrays will let you use it for free. Put it on your card. Return it and they credit your card. Open it up and inspect the pcs. and threaded parts. Idiots tear stuff up. Grease the threads of the screw.
needsrepair is offline   Reply With Quote
Old August 24th, 2007, 08:50 PM   #9
junk90xj
ALLPRO AUTO
junk90xj's Avatar
after. slide the axle shaft out. remove the upper and lower balljoint nut. use a bfh or air hammer or pickle fork to seperate he balljoints and knuckle. then take knuckle and sit it on the bench. remove balljoints with a press if you get one then stick it all back together.
Old August 25th, 2007, 05:26 PM   #10
Silver Bullet
thanks for the info i think im going to tackle tomorrow.
Old August 25th, 2007, 05:33 PM   #11
Cartman
Can't lose with 42s
Cartman's Avatar
Anti-sieze all the threads on any bolt to make it come back apart a lil easier...might be a few years before your back in there, will make it easier next time..
X2 on the autozone press
spicer and moog are respectable brands, I'd let the cost weigh which one I would use..
Cartman is offline   Reply With Quote
Old August 26th, 2007, 12:47 AM   #12
Silver Bullet
parts are free if i go with moog he is swapping them out if i go with spicer he is returning the moog and selling spicer for same price..he said spicer retails for more.
Old August 26th, 2007, 08:17 AM   #13
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
I would go with the more expensive free ones.
Old September 3rd, 2007, 09:36 PM   #14
Silver Bullet
well swap went great hardest part was beating steering knuckle off truck..i got an alignment at harolds frame shop in novi but they said it didnt need a camber alignment but my tires are still pitched in does anyone know a good place to have look at it..by the way the first time i went to harolds before i did the ball joints the said it definatly needed a camber align but after a differet guy looked at it and said no, is he a retard or what?
Old September 3rd, 2007, 09:41 PM   #15
mudd_jumper
mudd_jumper's Avatar
not any more they charge you the "deposit" then if you do not return it in two days they call you and ask you if you forgot to return it. Then charge you $6.00 when you return it. At lest that is what it is at mine in Shelby now.
Old September 3rd, 2007, 10:07 PM   #16
Silver Bullet
bump any references..
Old September 4th, 2007, 08:10 PM   #17
Silver Bullet
bump again any references on good place to get camber alignment
Page generated in 0.25960 seconds with 74 queries
