Dana Axle Info - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 22nd, 2012, 08:56 PM   #21
jroberts#77
Fuck there goes the trans
jroberts#77's Avatar
yeah it answered a lot of questions i had. great thread, cant let this get lost
jroberts#77 is offline   Reply With Quote
Old January 27th, 2013, 01:28 PM   #22
matthew
I got a 83 chevy k30 with '77 1 ton axles under it, heres my problem... replaced the seal on one of the rear hubs, still leaking... cant find replacement hub or even the whole axle, what can i do? any alternatives? the hub is worn that even with a new seal its still leakin! please help!!!
matthew is offline   Reply With Quote
Old January 27th, 2013, 10:11 PM   #23
littletrucker
I'd hit that
littletrucker's Avatar
That probably has a 14bolt rear end. Just replace it. probably one of the most readily available 1 ton rear ends. And even if you have a dana rear axle a 14 bolt should be a straight swap into a leaf sprung chevy.
Old May 6th, 2016, 11:53 PM   #24
Monty.Taylor
Send a message via AIM to Monty.Taylor
Default Dana 44 high pinion stud question
On a dana 44 high pinion 8 lug out of a ford . Im wanting to use it in my project but problem is lugs are smaller size then my 60 rear, is there a way or a solution in putting bigger studs in it. Thanks and i hope i posted this in the right place.. monty
Monty.Taylor is offline   Reply With Quote
Page generated in 0.18730 seconds with 35 queries
